Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Western Digital Elements external hardrive corrupted & unaccessable
Hello I've had a Western Digital Elements external hardrive [500 meg] for about 2 years now & I've just got myself a new laptop [with Vista] however I'm getting the error that the external drive is corrupted & unreadable. I've been told that if I could get access to it then I could do some for of 'disc-doctor' on it, but how can I do that if every time I try to get in there I get the same response..?
Regards
Chris
  • jmheaton Jan 15, 2009
    I have essentially the same problem on a 1TB external drive from WD.
  • Mohammed Ebrahim M
    Mohammed Ebrahim M Jul 02, 2017
    Do you need the data that was already in the harddisk?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
SOURCE: I cannot access western digital 1000 gb
Here is a tedious solution that works. Use MioNet and move all the files you want to keep to another drive or another computer, then delete everything from the MyBookWorld. Remove MioNet from all computers. Next access the drive's built in Shared Storage Manager with a web browser. Check the pdf manual on the install disk to find out how. Create a new shared folder and then move everything you want on the drive into the new folder WITHOUT using MioNet. Map the shared folder as a network drive for easy access. Never, ever, EVER use MioNet again and all should be good. The drive works, the MioNet software does not.
Posted on May 06, 2008
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
  • 397 Answers
SOURCE: Simpletech external 500GB Hardrive corrupted
PC INSPECTOR™ File Recovery 4.x is a data recovery program that supports the FAT 12/16/32 and NTFS file systems. The current version 4.x replaces the previous version 3.x, which is now over 6 years old.
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
Posted on Aug 03, 2008
SOURCE: XP doesn't recognize my external 500 GB WD My book essential edition hard drive
I had the same problem some have posted about. I had a lot of data on my drive and then one day it didn't show up in "My Computer" anymore. I had to assign a separate drive letter to the external drive.
Plug in the drive.
Right click on "My Computer"
Click on "Manage
Click on "Disk Management"
On the bottom half of the right side you should find "My Book" assigned to a disk number.
Right click on "My Book"
Click "Change Drive Letter and Paths"
Click Change
Select a new drive letter and hit OK
Hope this helps some people out.
Posted on Nov 06, 2008
  • 55 Answers
SOURCE: Broken Western Digital Elements 320gb external hard drive
hello,
there is nothing to do. you should brought new one. there is no other way.
thanks
ramesh
Posted on Nov 14, 2008
Is my external hard a plug and play?
In most computers that are encountered, devices that are plugged into the USB ports are "plug & play" capable. There are numerous scenarios that can turn this function off inadvertantly such as a virus, data corruption or driver changes. In order to fix the issue and make an external device, such as a Western Digital Passport Elite hard drive "plug & play" capable, a user will have to make a few system changes. Click "Start" and "Run," then type gpedit.msc Click on "Administrative Templates," from the tree then click on the "System" folder. Double click on "Turn off Autoplay." Select the "Disabled" option and ensure it applies to all drives. Hope this helps,
Dec 12, 2012 | Computers & Internet
Is this a plug and play drive?
Dec 12, 2012 | Western Digital 500GB ELEMENTS 500 GB USB...
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
Oct 28, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Hi.my Iomega external hardrive is not recognised in my computerbut it is on my main computer. I have cleaned my laptop after it was corrupted to it's original state and now it works as normal. but still...
If your drive came with an installation cd I would recommend that you install that first and then try to connect your hard drive after the disk installation, it should then be recognised. What version of windows are you using? It should be recognised by xp. Good luck. Andrew
Jan 18, 2010 | Western Digital My Book Essential Edition...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
My Western Digital Elements external hard drive is no longer recognised by either of my computers. When I attach it to computer it says it has found new hardware and installs it and when I look in device...
Check the Disk Manager to see if the disk has a valid partition and is recognized as being formatted. Start -> right-click My Computer -> Manage -> select Disk Management.
If not, then your MBR could be corrupted.
This troubleshooting external hard disk article should help you further.
Jules
Apr 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Im looking for a western digital 640 gb hardrive manual
when i plug it in, it doesn't make a sound to let me know that it is booting up, and also, the lights in the front of it, only lights up half of the way.
Feb 25, 2009 | Western Digital My Book Essential 500GB...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
173 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
