Question about Disney Mix Max Digital Media Player
Disney Mix Max
Just purchased a Cheetah Girls 2 video clip and it won't play. Keeps showing menu screen and all other videos play fine. Any suggestions before I try to return the clip?
  • locky616 Jan 08, 2009
    My daughter's Christmas Disney Mix Max player will play movies downloaded to a 1G sd card, but will not play the Disney Cheetah Girls 2 Max Clip and Pirates of Caribean Max clips that I just bought her. The player doesn't seem to be reading the card. It shows that a card is inserted, but when you press play nothing shows up under the card menu. Please help!
  • gina fanning Mar 04, 2009
    I'm having the same problem with Pirates of Caribean..It found the card but when I try to play it the screen turns dark. I reset the player but it didn't seem to help.
    Problem Solver:
  • 15 Answers
Oops, correction ... I reset it again and tried it and it came right on. It looks great, it sounds great. If you look on the bottom of the player you'll see a tiny pin-hole. Just stick a needle or pin in it, reset it and try again. Good luck.
Posted on Mar 04, 2009
I've reset it several times. The cards still won't work; but right now my daughter is enjoying the movies i downloaded for her. It is still frustrating, because the money was spent on the cards. I got a refund on one of the cards. I would still like any possible solution for the other non-playing card.
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
The Screen is not maximized on my Disney Mix Max Digital Media Player while playing videos
I solved this problem by using WME (Windows Media Encoder) per Digital Blue's website to re-encode the video, however, instead of choosing 220x176, I chose pocket pc widescreen in the new session wizard. This is found on the encoding options page in the video drop down box. This changed the video size to 320x240. Suprisingly, this worked.
Mar 31, 2009 | Disney Mix Max Digital Media Player
Is video playback supposed to be in full screen?
I have the same problem. I can't get the player to play the videos at full screen. I'm not sure why.
Dec 25, 2008 | Disney Mix Max Digital Media Player
Help Me!
Try pressing the reset button next to the USB connector on the bottom of the player with a thumb tack or paper clip.
Jun 17, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max
The Max Clip video cards are already in WMV format but have just have a .smv file extension so it's not necessary to convert them. Besides the Max Clip cards are read only so it's not possible to take the content off of the card to be converted and then placed back on the card. It's more likely that the problem is the firmware version of your player. Try following the directions at the link below for updating the firmware of your player.
http://digiblue.com/customer-service/faqs/disney/mixmax/17.html
If that doesn't work there is probably something wrong with your Max Clip.
May 28, 2008 | Disney Mix Max Digital Media Player
How do you put movies dvds and videos on your mix max mp3 player?
I think I've covered this one before... not sure though so here we go...
First of all DVD's are copyrighted and digitally encoded so that they can't be copied to your computer or other devices. Windows Media Player can't rip them because of this encoding. Not only that if you were somehow able to copy it to the player the Mix Max can't play DVD formatted videos, it can only play WMV (Windows Media Video) formatted videos that are properly "encoded" for play on the Mix Max.
Check out the link below for how to properly encode your videos for play on the Mix Max.
http://digiblue.com/customer-service/faqs/disney/mixmax/index.html
It has a PDF download with instructions on how to properly encode videos so that they will play on the Mix Max.
May 08, 2008 | Disney Mix Max Digital Media Player
Disney mix max
Did you try the reset button. you have to place a pin point or paper clip in the hole to reset.
Apr 27, 2008 | Disney Mix Max Digital Media Player
I want a format or software to play videos on my Disney
The Mix Max isn't an MP4 player. It's a WMA/MP3 audio player and it plays WMV videos. The videos have to be in WMV format to start and there are instructions on the manufacturers website on how to make sure that they are properly encoded. Here the link...
http://digiblue.com/customer-service/faqs/disney/mixmax/07.html
Feb 01, 2008 | Disney Mix Max Digital Media Player
How do i get videos on my mix max?
here it is, for those who nearly threw out those little things away, im not a techie but after 2 days i finally figured it out. whew! my 2 girls love youtube and music videos so for those who wants to get and play them instead of movies (the batteries on the mix max are not so good anyways) this is step by step, so be patient.
1. download youtube downloader (i usually download at cnet or sites you trust) to get those flv videos you like. (its quite easy to use and its free!!!)
2. download stoik video converter-(its free too) to convert those flv files to WMA, its quite easy to navigate but remember on the OUTPUT FORMAT choose wmv, i used WMV for ISDN 128, but...STILL in the output format click "edit profile" (scroll down to the end and you will see it) another window will pop out and change the frame size to 192x144 (mandymmof2 was right theconverted frame size should be at least the same size or smaller so thanks to him i was able to solve it)
3. go to windows media player or you can just open your converted video. drag it to the sync list, (but make sure your mix max is already connected and it says create a list to sync to mix max storage (internal/external whatever memory you choose to use)
remove and play...
FOR THOSE WHO DONT KNOW HOW TO DELETE SONGS/VIDEOS/FILES FROM MIX MAX .
you can delete it by clicking my computer, click disney mix max drive... the files you uploaded are all there to delete.
hope this helps!!
Jan 18, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
463 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
