Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer code f 10
Washer starts then 2mins it flashes f 10 then it empties
We had this happen and we had to replace the two parts......both parts together was about 150.00 We replaced them ourselves. Take off the top of your washer and try to run it and you will see a round wheel that keeps clicking and will not turn over.....your manual for the codes is taped under the bottom of the washer and this will give you the part and part number for each diagnostic code....at the bottom of your front loader there are 3 screws you will need to remove and the face will pull right off....then underneath that all your instructions on how to and what each code are in this book....we found this out after we hired someone to come and see what was wrong with ours and they were going to charge 450. to fix and we done it for 150...hoped this helped...
Posted on Feb 09, 2012
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Every time i turned on washer after 2mins into wash it will start to beep and the letter F will start to flash immediately the letter H will flash as well. It does not matter at what level or load I...
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Jul 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starts cycle the about 3 minutes into it 05 then f starts flashing and beeping
Whirlpool 'F05' decodes as 'NTC failure' - really helpful! NTC stands for Negative Temperature Coefficient (thermistor) or, in our language, it's the bit that measures the water temperature ;-0)
I have heard that pouring a few kettles of boiling water into the empty drum and leaving for 10 minutes can sometimes kick it back into life. It's worth a try anyway, otherwise it's a service call I'm afraid ;-0(
Sorry and good luck,
John C
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet washer door will not open
try pressing start and then pause/cancel immediately after. I just had this issue with mine
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer flashes f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-00 flashing control panel w/ time
pannick!........ suggest you check the filter, the fault code suggests that for some reason it cannot empty. Regards Engineer
May 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
