Question about Kenmore 54701 Dehumidifier
Not working I purchased the dehumidifier one and half years ago. It just stopped working. It sounds like the fan is clicking but thats it. It lights up and displays the numbers of degrees but thats it. You can even push buttons to change settings.
The key in the fan blade is soft plastic and it rounds out and the fan slips. also it can make a clicking sound or banging sound because the broken key causes the plastic sleve that slides over the motor shaft cracks.
Posted on Sep 23, 2007
Mine did the same thing and i had to replace the fan
Posted on Mar 02, 2007
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
My HDN455 45 pint Dehumidifier did not work
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2009 | Haier HDN455E 45 Pint Dehumidifier...
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Goldstar Dehumidifier model# DH305Y7
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
May 27, 2008 | LG DH30 GoldStar Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Dehumidifier not dehumidifying ...
Save the old one for parts if you get the same new one but I def. don't reccomend buying this unit again. The reviews are bad. The fan is not covered under the warranty except first year or extented warranty. I spoke with Kenmore & Sears about this to see if coverd under 5 yr. Only compressor,tubing & refrigeration system(see inside of front cover for warranty info.)
Sound more like a sensor/circuit board problem to me since fan is turning. I think the signal determins which setting fan needs via sensor assembly to run. I could be wrong. Justa thought.
Can you def. hear the compressor come on. You can look through grill to see fan spin & the compressor makes a clank/clunking noise/ The fan & compressor should turn same time. Good luck! If you got any info. on my fan problem & you have update or fixed your problem I ccould use some help. Check post for my problem.. Thanks! panfan1
Aug 13, 2007 | Kenmore 54701 Dehumidifier
Kenmore 54701 Dehumidifier Logo
244 people viewed this question
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
