Question about Microsoft Xbox 360 Console
What causes the 2 red lights on xbox?
Xbox turns on the goes off with two red lights on.
    Scholar:
  • 87 Answers
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire.
Posted on Oct 22, 2008
  • 11 Answers
SOURCE: power supply to xbox 360
2 red lights on part 1 and 3 indicate the the console is overheating, the most common problem is the thermal paste.
You need thermal paste or it will overheat instantly, using cheap thermal paste or not using enough thermal paste will also cause problems. Use good quality paste and apply enough to make contact. You don't want to use too much, but if you use too little it won't make good contact with the heatsinks.
If you've done this before then it shouldn't take too long, but if you haven't then just take your time. You don't want to put too much on at first so do it bit by bit.
If you're still getting this error after correcting with thermal paste then the only suggestion would be to contact Microsoft but then they might not take the 360 after you have already void any warranty by opening up the console.
Posted on Apr 20, 2009
  • 23 Answers
SOURCE: 2 red lights
If your box never has been open you could send to MS for repair but since it is not the 3red rings error. They will charge you I think. You'll have to call and tell them your problem. If you want to fix the problem yourself you are going to have to open the box. Once you have it open you got to check the fan. Look and see if any wires came lose,disconnected or burnt up. If they seem ok check the clip attached to the motherboard. Just follow the wires on the fans. Pull the clip out push it back in. This is to make sure clip is in tight. You dont have to put the 360 back together to test the fans. Plug the power in and the video cable and boot it up. If it works great if not your going to have to buy replacement fans. http://www.talismoon.com/cgi-bin/version2/engine.pl?page=product-xbox360-whisperfan-red
Posted on Sep 27, 2007
  • 16 Answers
SOURCE: 2 red lights xbox 360
hardware problem... when it over heated it must of melted somthing in it... mine did that too
Posted on Apr 06, 2009
mind397
  • 16 Answers
SOURCE: 2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Posted on Jun 30, 2009
  • 297 Answers
SOURCE: My xbox will not turn on
Yes this is the overheating problem you need to stop the heat build up you can use a good guide or send it in to get it fixed.
Posted on Jul 15, 2010
Jul 15, 2010 | Microsoft Xbox 360 Console
My xbox flashes 3 red lights then goes to 2
Hello Mr .
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
May 19, 2010 | Microsoft Xbox 360 Console
What would cause a 2 ring malfunction?
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
2 red lights is purely overheating.
Feb 22, 2010 | Microsoft Xbox 360 Console
Two red lights come on after playing and the screen goes blue what do the two red lights mean?
Two red lights on your xbox mean that the xbox is overheating. Turn off the xbox and let it cool down for about an hour, maybe 2. While it is cooling down make sure that the back of the xbox is clear and has enough space for ventilation and make sure that it is clean so that air can flow properly through the system to cool it down while you're playing.
Jun 04, 2009 | Microsoft Xbox 360 Console
Red light on first xbox
Cracked solder points try turning it on with the fan unpluged and wait untill you get the 2 red rings lights 1 and 3 then wait until the xbox shuts off then wait a couple of min. then reconnect the fan and turn it on to see what happends.
May 23, 2009 | Microsoft Xbox 360 Console
IGOT 3 RINGS OF DETH
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow the steps below, Hope this helps
Dont worry shipping and handling will be covered.
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
343 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
