Question about Canon EOS 1100D / Rebel T3 Digital Camera
Camera. Card's write protect switch is set to lock
I try to write protect my pictures on my camera canon eos rebel t3 after that i cant snap i cant do anything when i press the shutter button then it write cards write protect switch is set to lock please help me
Posted on Jul 16, 2013
willem52
  • 359 Answers
SOURCE: Canon rebel xsi - have
Put a new or another memory card in the camera and recheck.
If it gives the same problem, the camera needs probably maintenance / repair.
Posted on Sep 13, 2011
michaelleo
SOURCE: camera setting is stuck on
You should take a look at the actual memory card and make sure there is not a lock (a small slider you can use to protect the card from being overwritten). To check it:
  1. Turn off the camera.
  2. Open the port that holds the battery and memory card.
  3. Remove the memory card
  4. Look at the memory card and see if there is a little slider that can be moved from an On to Off position. There should be a little Lock drawn near it.
  5. If there is such a slider, make sure it's set to the Unlocked or Off position.
  6. Put the card back in the camera and close the door.
  7. Turn on your camera and you should be good to go.
Posted on Oct 23, 2010
SOURCE: card locked
There's a little yellow switch on the left side of your memory card labled "lock" with an arrow pointing down. Push it up. Note: If it doesn't work right away, try uploading all your photos to your computer and then dumping them off of the card.  Push the switch up again and it should start taking pictures again.
Posted on Dec 23, 2008
SOURCE: when i turn on my
check your SD card if its on write protected,theres a switch on the sd card
Posted on Jun 18, 2011
  • 11967 Answers
SOURCE: Canon Rebel eos is locked on Card protected. How
Does the card contain pictures shot on another camera? If so, that could be your problem. Download those and format the card in your camera.
Posted on Jan 16, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
When switching on camera it keeps saying protected card and I can't do anything
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 24, 2012 | FUJIFILM FinePix S1600 Digital Camera
Card's write protect swiitch set to lock
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 22, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Camera is locked up. screen says it has a 'protected card'
there's a write protect tab on the card. if this is in protect them you can't write to it [save photos]Also, if the tab is in the right position, the sensor in the camera is either blocked [optical] or damaged [electro-mechanical]If it's blocked, use 'dust off' canned air to blow out the card slot.If it's a switch, it'll have to go in the shop.
Hope this helps.
Mar 22, 2012 | Fuji Finepix J50 Digital Camera
How do I 'unwrite protect' camera?
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Jan 05, 2012 | Cameras
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
When I turn on my camera, it wont let me take a picture, it says write protected. If I take out my SB card, then it will let me take a picture. What do I do?
If the memory card is an SDHC card then that is probably the problem. Look at the card, does it say SD or SDHC? I don't believe the camera can use an SD High Capacity card.
If it's a regular SD card, then check the "Lock" switch on the side and make sure it is not set to "Lock". If it's NOT set to "Lock" and NOT an SDHC card, then the problem is inside the camera. There is a small switch on the mainboard of the camera that the little "Lock" switch on the memory card pushes. If that switch is damaged then it will not be pushed by the switch on the card properly and the camera will think the card is locked.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 24, 2011 | General Electric W1200 Digital Camera
My camera is saying card protected.So when it says that i can't take or delete pictures.So how can i take that off?
SD card have a switch on the side for write protection. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Card Switch in Downward "Locked" Position (note the arrow by the word "Lock")...
Card Switch in Up "Unlocked" Position...
Hope helps.
May 26, 2011 | Vivitar ViviCam 8025 Digital Camera
Canon EOS 1100D / Rebel T3 Digital Camera Logo
1,763 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
