Question about Technics Audio Players & Recorders
How to put preset stations into memory on technics st-s77 tuner
How to put stations into the pre-set memory.
SOURCE: How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Posted on Dec 28, 2008
nokurajesh
  • 101 Answers
SOURCE: How do I set the preset stations on my Technics
press and hold the station button for 10 seconds
Posted on Jan 10, 2010
welcomejee
  • 10594 Answers
SOURCE: How do you adjust the AM bandwidth on a Technics
Check at bottom, there would be little slide switch with settings 10KHz--9KHz marked on bottom.
Posted on Jun 19, 2010
  • 11800 Answers
SOURCE: how do I create preset
I would help if i knew what tuner you are referring to.
Posted on Nov 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a technics ST-X933L
You can answer the question by jacking the tuner's outputs into any other Line Level input on your amp/receiver. If it's still low, the tuner is at fault.
BTW: NEVER use full volume as a test unless you intend to blow up your speakers.
Posted on Mar 06, 2011
Technics st-hd81 tuner
You need to take it in for service. The stations are not kept in the remote but in the unit itself. There is a small battery that holds the memory when the unit is switched off.
Jul 21, 2016 | Miscellaneous
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
Technics ST-S3
1. Select the lowest FM frequency you want manually. You should hear it.
2. Press MEMORY followed by preset one.
3. Repeat the process for the remaining frequencies and buttons.
If you don't hear anything when you tune manually, the frequencies are not being received with enough strength. There could be an antenna problem.
Dec 28, 2013 | Audio Players & Recorders
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
Dec 13, 2008 | Technics Audio Players & Recorders
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
44 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
