Question about Linksys Computers & Internet
Xbox nat setting moderate; NEED TO ENABLE UPnP
According to Windows Live recommendation, we are trying to enable UPnP on router but cannot see how that is done.
Need to open NAT for Xbox 360. Router is a Belkin DIR-628 and has already been port forwarded...
In order to open NAT settings for the xbox 360 you will need to enable Universal Plug N Play [UPnP]
To enable this setting in the Belkin DIR-628:
1. Log into the router
2. Click on the "Advanced" Menu on top
3. Click on the Enable UPnP: Checkbox
4. Click on the Save Settings Button
May 01, 2011 | Computers & Internet
My nat settings for my xbox 360 is set to strict, I am connected to xbox live from my laptop, my laptop is connected to my linksys router, how do i change my nat settings to open if my connection is set up...
You'll need to log into the linksys router and find the setting for UPNP. Please make sure this is enabled. That should allow your NAT setting to at least Moderate, if not Open.
Mar 12, 2010 | Microsoft Xbox 360 Console
My NAT type is moderate and will disconnect me from my X-box live party.
try this option as follows:-- just enable the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run xbox test again.
click on this link directly for more detailed help xbox-live-compatible/">http://midnight.hushedcasket.com/2007/01/30/make-your-router-xbox-live-compatible/
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 08, 2010 | Zyxel Prestige P-330W Wireless Router...
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
The nat type for my xbox 360 is set to moderate
Enable UPnP.....UPnP can help make sure NAT works correctly for Xbox LIVE. Usually, this can be set on your router configuration web page, which is supplied by your router manufacturer.
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
I need to open the nat on my router for xbox live and dont know how
go into the router settings and look for uPnP and enable this it will then open the firewall for your xbox automatically
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NAT set to strict
upgrade your router to the latest firmware that can be found here:
http://kbserver.netgear.com/products/WGR614.asp
after upgrading the firmware, press the reset button for 30 seconds, then reconfigure the router. you will need to re-enable upnp if it is disabled, and open up ports UDP 88 UDP 3074 TCP 3074. i would also reserve the ip for the xbox and if all else fails set the xbox as the dmz host.
hope this helps,
trin
Nov 16, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
436 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
