Question about Samsung Dryers
Where I's the ignitor located on my samsung dryer?
    Top Expert:
  • Samsung Master
  • 79,852 Answers
It is located inside the dryer cabinet.
Posted on Feb 06, 2012
Dryer wont fire up glow plug lights up the you hear click and shut down then 30 seconds later it'll repeat its a model # GLGR341AS3 Frigidaire dryer any advice would be helpful THANK YOU
Hello, first of all, I'm posting a link that has diagrams of your dryer and all of the parts within. This will help you determine where the components are located that I'll be mentioning. Now, you may find your problem if you follow this guide half way through. But the problem is probably located somewhere within the burner. So when you pull up this link, look at the burner diagram, and you'll locat the things i'm talking about.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=glgr341as3&mfgModelNum=&fkMfgID=4
I urge you to get some type of meter for testing, whether it be a voltohm analog style meter, or even a digital one. They will be around 10 dollars for the anolog version, and 20 dollars and up for the digital versions. Dont let it intimidate you if you dont know how to use one. I've posted a link below that will show you EXACTLY how to use it for these tests. At the very bottom of the everything, I'm posting a few links that will show you how to change the defective parts out.
If you're lucky enough to have a viewing port; To observe the burner, look for a small cap located on the front of the dryer. either to the left or the right. You can pry it off with a flat head screwdriver.
This cap is a viewing port to observe the burner assembly. Now you want to start the dryer on a cycle that will require the dryer to engage the burner. You are waiting to see if the ignitor is going to glow; knowing this will cut the possible causes of gas dryer heating problems in half. If you dont have one of these holes to see through, you will have to remove the top and front of the dryer.
IF THE IGNITOR GLOWS, you know that it's okay, you also know that the thermal fuse in the back of the dryer is okay.
NEXT, you'll want to see if it turns OFF. If it didnt I'll cover that later. If the ignitor clicks off after a few seconds of glowing bright orange, You know that the flame switch mounted to the left of the burner tube is OKAY as well.
At the moment the click of the flame switch is observed, the burner valve should release gas for burner ignition. If the ignitor turns off with no ignition, and you are positive you're getting gas supply to the dryer, you likely will have to replace the two coil valve solenoids on the top of the burner. The valve itself is extremely reliable and rarely needs replaced.
The two safety coils may gradually fail over weeks, or even months giving longer dry times and only partial heating. As safety coils are failing, they'll work fine for only a short amount of time, and then after about 30 minutes of cycling on and off to maintain the drum's temperature, they will break down and cease to open the valve leaving you with cool or wet clothing at the end of the cycle.
IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF you likely have a bad flame switch (flame sensor).
Perhaps; THE IGNITOR DOESN'T HEAT UP AT ALL, you will have to check the possible causes in order of likelihood. You will need to check.........
1. THE THERMAL FUSE- This is usually a small white strip with two wires attached. It is designed to burn out when it senses that the dryer has reached an unsafe temperature. If you find it to be the problem, you'll want to make sure that the ducting is moving air out of the house unobstructed.
The easiest way to check this fuse is a voltohm meter. You can get them for under 20 dollars. Dont worry, I've posted a link at the top that shows you how to use one. Dont be intimidated by it, it's super easy once you know a few details of how to use it.
http://applianceassistant.com/safety/how_to_use_a_volt_meter.php
OK, back to the thermal fuse. Make sure dryer is unplugged, disconnect the two wires on the fuse, You will set the meter to read ohms on the lowest setting.
The setting is usually RX1, or RX1K. Touch a test lead to each terminal and you should get a reading of ZERO ohms (you could also say ZERO resistance), meaning that the fuse is allowing electricity to flow through it and on to the IGNITOR. IF> you the fuse tests open, you'll need to replace it. IF it's okay, you need to keep going.
Now you need to lift the top and remove the front.
From the inside, you can see the burner valve, the valve coils, the ignitor, and the flame switch a little better now.
SNENARIO: The ignitor isn't glowing, you've tested the thermal fuse and it was okay.
Now you want to test the FLAME SWITCH and the IGNITOR.
TO TEST THE IGNITOR:
You will use the same test for the thermal fuse. Disconnect the plug coming directly of the wires of the ignitor. The plug on the ignitor side will have two prongs in it. You will touch the meter's leads to these two prongs. This time you should get a little resistance, meaning if you're using
an anolog voltohm meter, the needle should be just a touch above zero. If the needle doesnt move at all, that means that it's open and "BAD." If the IGNITOR tests okay, then move on to the flame switch.
TO TEST THE FLAME SWITCH:
Test it the same way as the fuse and the ignitor. Remove the 2 wires that are connected to it. Remove the screw that holds the flame switch on and take it out to test it. Touch the 2 test leads to the terminals that the wires were connected to. This should look the same as the fuse, having ZERO resistance. This means that power can flow freely. If the needle doesn't move at all, then the resistance is infinity, meaning the component is bad. You should use caution when removing the wires from the flame switch, you should support the terminal with a pair of needle nose pliers and use another pair of pliers to remove the connectors from the terminals of the flame switch. You should never pull the wires themselves.
If all of these components are okay, then you've successully completed the common 90% of heating problems in a gas dryer. Any component that is tested above should be replaced if it tests bad.
The other 10% should be left to a technician. You need to have an understanding of your wiring diagram specific to that dryer to see where the problem is in the circuits. MOST of the time, your problem should be solved before you even get to this point.
http://www.youtube.com/user/RepairClinic#p/search/1/tMqublMvau0 FLAME SENSOR REPLACEMENT.
http://www.youtube.com/user/RepairClinic#p/search/0/Mj7Q-SexmGQ GAS VALVE SOLENOID REPLACEMENT
http://www.youtube.com/watch?v=iK9q6K7iIrQ&feature=mfu_in_order&list=UL HOW TO REPLACE AN IGNITOR
GOOD LUCK. I will be happy to assist you further if you need me to. I hope this helps solve your problem.
Thanks,
Mike
Aug 01, 2011 | Dryers
Dryer runs but there is no heat, is there a reset button? model dv218aeb
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';'
Jul 31, 2011 | Samsung DV218AEW Electric Dryer
Dryer not heating up the duct is cleared of lint
heatman101';
Jun 28, 2011 | Samsung Dryers
Not heating
heatman101'
';][\p
Jun 23, 2011 | Samsung DV218AEW Electric Dryer
Maytag dryer mug15pdaww won't light, the ignitor
heatman101
Jun 16, 2011 | Maytag Dryers
I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
Thank you for contacting fixya.com.
If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
Please get back to us if you have further query else please accept the suggestion.
Jun 15, 2011 | Dryers
Dryer Not Heating, no error messages. We have checked the filter and vent and all are clear.
heatman101;
Jun 15, 2011 | Samsung DV448AEE Electric Dryer
We were turning our drum and heard a loud pop sound; plus the clothes hadn't gotten dry.. the lights and everthing shows up but the dryer won't start up now
heatman101'';
Jun 13, 2011 | Samsung Dryers
heatman101
May 15, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Samsung electric dryer model # DV328AEW not heating up to dry clothes
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
Dryers Logo
88 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
