Question about Xerox Phaser Office Equipment & Supplies
Xerox xc 1020 red light
Red light is on does not print
Can you please help me to reset may old model selex GR-1020
Posted on Jun 15, 2013
  • 2072 Answers
SOURCE: Can you help us with a copier problem
That sounds like your toner is empty. Sometimes that cartridge runs out or low on ink and just doesn't display.
What is happening is the density sensor is looking for a nice black patch and the patch it is looking for is gray or almost blank and it stays in a constant cycle of trying to make that ink patch dark enough to produce a copy,
I would try a new toner.
Posted on Jun 09, 2008
vmachlis
  • 7 Answers
SOURCE: Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Posted on Dec 21, 2008
  • 2072 Answers
SOURCE: jamming, when I open it there is a half printed page inside.
Open the machine up, look at in the back area of the machine, just where the paper enters the fuser, ( hot area of the machine). You will find a broken gear, most likely black in color. Most likely you will find it laying in 3 or 4 pieces.
That gear is a common failure in that machine.
What to do, Google a business called "the parts drop". Give Britt a call, he will have that and at a very fair price. ( No I don't work there, but have done business with them for a long time. Trustworthy and honest.), If he doesn't have instructions on how to replace that. Ask me and I will write them out for you. Pretty easy repair. Probably a half hour or so.
Posted on May 13, 2009
  • 2072 Answers
SOURCE: Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Jul 01, 2009
  • 53 Answers
SOURCE: there are 3 lights on the xerox 1020 first one
you replaced the drum too soon, replace old drum until red light flashes then install new drum.
Posted on Jan 22, 2010
Tip
Xerox XD or XC Series Copier Drum Light Drum Unit Reset Procedure
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works on nearly all Xerox XD and XC Series copiers.
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
The fuser error light is on and my Xerox XC 1040 copier will not work. There is no error codes displayed
The drum light can be reset via the control panel. Especially if your copies were good before the light came on. The drum unit is the cartridge that is located right next to the toner cartridge. Reset the light using the following reset procedure:
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 12, 2010 | Xerox Office Equipment & Supplies
There are 3 lights on the xerox 1020 first one
Jan 22, 2010 | Xerox Office Equipment & Supplies
My xc 1040 the little triangle keep flashing red and wont let me do anything else
Hello sir; The red triangle indicator light on, it means need toner, just replace toner cartridge shpuld be fine.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
1.Clear button
3.Clear button
4.Auto button
Sep 02, 2008 | Office Equipment & Supplies
Jun 09, 2008 | Xerox Office Equipment & Supplies
Hp laser jet 1020
My friend had the same problem. A small sliver of paper was blocking one of the contacts where the cartridge connects with the printer. Removed it and voila!
Nov 01, 2007 | HP LaserJet 1020 Printer
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
