Question about Lexmark X7675 Aio Wl USB Adf 32/27PPM Ocr Dir Prt Pbridg Dplx All-In-One InkJet Printer
Power belt is knocking - Lexmark X7675 Aio Wl USB Adf 32/27PPM Ocr Dir Prt Pbridg Dplx All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Try to open the printer cover and access the cartridge area. Make sure the carrier belt is properly seated in its place. If not, please contact Lexmark Technical Support Center for additional assistance.
Posted on Feb 09, 2012
Why is engine knocking?
the serpentine belt is an accessory drive belt --a/c --alternator--power steering--water pump--etc it does not have affect on timing ---if you have an engine knock while running that would more than likely be a "rod knock" "piston knock" from a burnt main bearing,piston wrist pin ,damaged rod --if your timing was off poor running ,misfire,no start ,banging in upper engine valves hitting piston,
Oct 06, 2015 | 2000 Pontiac Grand Prix GT
95 Buick Regal .it makes a knocking noise when running,but when I take belt off it stops.I replaced the water pump and it still knocks.
Said "knock" could be in the AC compressor or power steering unit since it don't knock with belt off.
Aug 24, 2014 | 1995 Buick Regal
Sound inside the engine
Does the knocking sound increase with engine speed? Check all the things run by the belts, like A/C, alternator, etc. by removing the belts and starting the engine. If there is no more knocking, then check those components. If the knocking is still, you may have an internal engine problem like main or rod bearing failures. Check the engine oil for any metal flakes.
Mar 31, 2014 | Hyundai Accent Cars & Trucks
1995 toyota camry sound from lower timing cover, and loss of power selectively
Depends if it is a no tolerance motor, which means bent valves.
May 24, 2017 | 1995 Toyota Camry
Location of the knock sensor on a 2002 kia sportage
remove the intake manifold ,remove radiator ,remove radiator intake and outake housing, remove fan ,remove all belts: power steering, alternator and if you have a/c, remove harmonic balancer ,remove timing belt covers, remove timing belt remove intake housinng once you have remove all the above, your freaken engine will look naked, you can see the location of the knock sensor is locate in the engine valley u might wanna google knock sensor so u knoe what it looks like
Feb 19, 2010 | 2002 Kia Spectra
How do I replace the Knock Sensors on a 2002 GMC Sierra 2500HD 6.0L V8 Gas engine? How do I change the serpentine and AC belts? Last but not least how to replace the drivers front differential seal?
remove the intake manifold ,remove radiator ,remove radiator intake and outake housing, remove fan ,remove all belts: power steering, alternator and if you have a/c, remove harmonic balancer ,remove timing belt covers, remove timing belt remove intake housinng once you have remove all the above, your freaken engine will look naked, you can see the location of the knock sensor is locate in the engine valley hope this helps u might wnat to google knock sensor so u knoe what it looks like
Feb 19, 2010 | 2002 GMC Sierra 2500HD
Replacing an anti knock sensor on a 2000 ford
Jan 29, 2010 | 2000 Ford Focus
How to replace knock sensor in 1995 nissan altima
Jan 20, 2010 | 1995 Nissan Altima
Knock sensor location 08 accord
Dec 31, 2009 | 2008 Honda Accord
Knock in engine
will831, If you will go to your local auto parts store and get an additive that is called Lucas Oil Treatment, it may helps to stop or quiet the knocking that you are experiencing. Also, Lucas has a great fuel additive that cleans your fuel injectors. I highly advise using both of these products intermittantly, to keep your engine in great shape.
Respectfully,
Terry
May 15, 2008 | 2003 Chevrolet TrailBlazer
Lexmark X7675 Aio Wl USB Adf 32/27PPM Ocr Dir Prt Pbridg Dplx All-In-One InkJet Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
