Question about Casio CS43 Stand for CDP 100
Disfunctioning f note. It plays extremely loudly.
Hi there. I bought my CDP 100 about two weeks ago and the third lowest F is not functioning properly at all. It gets really loud whereas the rest of the keys play normally. It is so annoying and even when i push the key ever so slightly it plays a very loud note. Can I fix it or should i exercise my warrant on it rather?
  • Layne Bratvold
    Layne Bratvold Dec 11, 2013
    I realize this post is almost two years old but I had the same issue. The problem was, as John mentioned, a blob of solder that was shorting two of the key matrix signals on the main board. See picture. It took about 40 minutes total to open the unit, remove the solder bridge and re-assemble it. Good as new (better in my case).
    Genius:
  • 1,212 Answers
If it is under warranty, may as well make use of it. In the long run it will be less headache for you.
It is something that should be repairable, although time consuming. as it is likely a stray bit of solder lodged where it should not be.
Posted on Feb 07, 2012
Key B2 playing to loud, not touch responsive
What is your piano brand and type?
Damage to the contact rubber can cause note plays loudly or,
note does not plays at all.
It is caused by:
1. Carbon rubber contacts dirty / dusty (yellow arrow). Clean with a pencil eraser (or cloth). Gently rub it.
2.
Contact rubber is torn (your case). If this happen,it can not be repaired or glue. So, you have to replace one octave.
The yellow arrow indicates the side that is often torn.
Rubber side that is torn, usually not seen, unless we move / pressing gently on top (In the rubber contact position is not installed on the board.)
Examples of this picture was yamaha psr.
Oct 14, 2015 | Music
The third G key on my Yamaha YPT 300 does not cooperate with the touch response feature. Regardless of how hard I press it, it plays the note loudly. All of the other keys are fine.
Below the keyboard, there is a rubber contact (see figure 1).third-g-key-yamaha-ypt-300-not-cooperate-shyexoo0xcste5eq310zs3ot-4-0.jpg Damage to the contact rubber can cause:
- Note plays loudly or
- Note does not plays at all.
It is caused by:
2. Contact shredded rubber. If this happen,it can not be repaired or glue. So, you have to replace one octave as in Figure 1.
Sep 27, 2015 | Yamaha Music
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
Note not functioning
Possibly dust. May need to make an appointment to see Dr Casio if you haven't got it fixed yet
Sep 24, 2013 | Casio Cdp-100 88 Note Digital Piano
A bought an Yamaha DGX 640 grand a week before and the note sustain for a longer duration and overlaps with the current playing notes. I checked the sustain in the function setting and it is also showing ...
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Mar 06, 2011 | Yamaha DGX640 Music Keyboard
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
May 05, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CS43 Stand for CDP 100 Logo
142 people viewed this question
Top Casio Music Experts
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
