Question about Lexmark X6570 InkJet Printer
Knocking sound when copying - Lexmark X6570 InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Problem: Carrier not moving to the loading position
If you're having trouble with the cartridge carrier not moving automatically to its loading position (to install/replace cartridges) even when the printer is on and the cover is open, please follow the steps below:
  1. Unplug the printer from the power source.
  2. With the printer cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the carrier to the center of the printer.
  3. Open the latch and remove the used cartridges.
  4. Load the new cartridges. Close the latch and then the printer cover.
  5. Re-plug the printer to the power source.
  6. After going through the startup process, try to print a document to verify that the cartridges are working and installed properly.
Posted on Feb 09, 2012
My Sharp AL-1655C makes a knocking noise when I turn it on, how can I repair this?
more than likely it is the fuser section the gear sometimes breaks and causes the knocking sound.
Jan 20, 2015 | Sharp Office Equipment & Supplies
Loud knocking sound when copying on a bizhub 162, why?
replace the drum and developer and sounds like the fuser need to be replaced
Apr 10, 2014 | Konica Minolta Office Equipment & Supplies
Knocking noise
The only thing that moves inside the PC that can knock with those effects is the hard drive. The knocking sound is the heads constantly re-parking and trying to synchronize to the platters. That is a sound you don't want to hear. I would IMMEDIATELY copy off ANYTHING that you don't want to lose forever from that disk, because death is imminent.
Dec 04, 2013 | HP TouchSmart Computers & Internet
My red dead redemption game will not read when I put in the disc. It keeps saying Play DVD.
Did you purchase the game brand new or pre-owned? or is it a knock off copy? i only ask about the knock off copy idea because members of the military can aquire such things quite easily.
Dec 31, 2010 | Rockstar Games Red Dead Redemption for...
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
1998 mustang knocking.
go to an autozone and if they do not have it go to napa and check on a price for a knock sensor and you can also try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 19, 2009 | 1998 Ford Mustang
Scanner failure is holding up the whole printer
Sorry, a common HP printer problem....uneconomical to repair.
Jan 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Knocking noise
sounds like the developper
it may start to stiffen up.
remove the developper (toner cartridge and try turning the gears by hand, if it's practically impossible to do) replace.
Aug 12, 2008 | Sharp AR-M277 Black and White Copier
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Lexmark X6570 InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
