Question about Singer 14SH654
How to replace upper looper in Singer ultralock 14SH654
SOURCE: Trouble with singer ultralock 14SH654
The motor could have gone...........Did you smeel plastic burning?The footpedal may be broken.Ask a shop if you can buy one and return it if thats not the problem..
Posted on Mar 21, 2008
  • 136 Answers
SOURCE: My 14sh654 singer Serger tension must be off and
possible causes. not threaded correctly, actual probelm with tension, burr on neelde plate presser foot or looper. check to see if after you thread that particular tension if there is any resistance on the thread after it passs thru tension, if not see if thread or lint is in tension disc. clean out it present then try again.
Posted on Sep 27, 2009
SOURCE: I had to rethread my Singer Ultralock serger and
what should the tension dials be set on? A general idea. And, do you know what function each dial is? I do not have a manual for my machine.
Posted on Jan 07, 2010
  • 1116 Answers
SOURCE: Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Posted on Mar 24, 2010
  • 1788 Answers
SOURCE: I have a singer Overlock
Yes, it can. What do you have your differential set at? Try it in the middle and see if it makes a difference.1 is usually for overedging, 2 is usually for easing in a sleeve, etc. I have my tensions set at 4,4,4,4, stitch length at 3 to 4. Do not be afraid to try gradually changing the tensions, but do them one at a time, that is what I did and finally got it.
Posted on Mar 17, 2011
I need a manual for my Singer 14sh654 ultralock.
You can find a threading diagram at this site:
www.singerco.com/uploads/assets/pdf/14SH654_threading.pdf
or download the full manual at this site:
http://www.manualslib.com/products/Singer-14sh654-701520.html
May 13, 2015 | Singer Sewing Machines
Need part number for a part on singer 14sh654
Singer has a PDF with the illustrated parts list for the 14sh654 available here: http://parts.singerco.com/CPpartCharts/14_CG_J_SH_T/14SH644_14SH654.pdf . There are two different models listed for 14sh654 manuals. However you can download them (or buy them). To download the Ultralock with incandescent lamp manual, go to http://www.singerco.com/uploads/download/434_14sh644_654_e.pdf . For the Finishing Touch (LED lamp), the manual is http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf .
I hope this helps.
Sep 24, 2011 | Singer 14SH654
What setting are the three threads set on for a rolled hem on a singer ultralock l4sh654 and what is the lever by the plate for?
Rolled hemming on any overlocker is usually achived the following way. Right hand needle only.
Blade over to the right usually to cut wider than normal but you can vary this to suit the fabric and stitch width you want.
Thread in this needle and the upper and lower loopers. If you can source any, use woolly overlock thread in the upper looper, this fluffs out when not tensioned and covers the fabric to give the look of solid stitching. Change upper looper tension to about 2 and lower looper tension to about 6 or 7.
The lever by the plate is usually to control the little stitch finger where the stitches are formed, move it backwards and it should move back towards you?? If this happens, then you want it in the retracted (towards you) position for rolled hemming so the stitching is much smaller and the fabric can roll. Normally this stitch finger holds the fabric firm for the loopers to form the stitch over for your normal 3 or 4 thread overlock.
Now test stitch and see how it looks. Tighten the lower looper thread so it lays right beside the needle on the underside. You may need to then tighten or loosen more the upper looper, you want the upper thread to wrap all the way around to the underneath against the lower looper thread and needle.
The cut edge of fabric should roll to underneath inside your seam. Once you've got this happening, turn the stitch length down to 0.5 or so to close it right up tight. This uses heaps of thread so I usually test everything else, then close it up at the end to minimise waste.
Hope this makes sense, good luck.
Sep 22, 2011 | Singer 14SH654
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Sep 04, 2011 | Singer 14SH654
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
I have a Singer 14SH654 (overlock) and broke the foot piece that is attached to the shaft. I can't find a diagram to identify the part number so I can order a replacement.
Call Singer at 1-800-4singer and they can advise you. They have a website at www.singerco.com and you can download your manual manual for free, kind of nice to have a back up on your computer, plus have the luxury of enlarging the diagrams.Another tip, go to www.sewingpartsonline.com and you can see what your part should cost approximately, plus identify what your part is called. Good luck
Jan 07, 2011 | Singer 14SH654
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
Lower Looper Shaft
MY LOWERLOOPER HAS SNAPED
Mar 15, 2008 | Singer 14SH654
Singer 14SH654 Logo
137 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
