Question about SaniServ Ice Cream Makers
SaniServ M - A4071-E Manuals - SaniServ Ice Cream Makers
Where do I find out what size o rings to order?
Take them out and take them to an industrial fasteners supplier. Or order direct.
http://saniserv.com/support.cfm
Jul 07, 2015 | SaniServ 407 10 Quart Ice Cream Maker
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
Wiring diag. for mod. 407-E Ice Cream Maker
Need the serial number, voltage (ie; 115v or 208v), 60 or 50 hz.
The only exact diagram for an 407-e is 50hz.
An M will be close in most cases as long as we have the serial number or Mfg. date code.
If it is a 407-e 115/60Hz with a blue id plate it is at least 15 yrs old.
Nov 09, 2010 | SaniServ 407 10 Quart Ice Cream Maker
I need parts list
spec for belting - size and mesurement
Jul 11, 2010 | SaniServ 401 20 Quart Ice Cream Maker
Looking for a manual for my Saniserv 407. Any info would be VERY appreciated!
I was able to get you a phone number where you can inquire about the manual you need 1-866-892-6344 and a website that sells this product.
http://www.instawares.com/saniserv-soft-serve-ice.ssm-407.0.7.htm
it appears to be distributed by a third party called instawares. good luck
Dec 29, 2009 | SaniServ 401 20 Quart Ice Cream Maker
Same Machine
In the 1990s SaniServ manufactured soft serve ice cream makers for slush puppy Corporation and call it freeze bee model A 501 which is the same machine as SaniServ model 501...........
if you go to www.saniserv.com or call their phone number at 317-831-7030 and give them your serial number they will give you all the information you need, when inquiring ask for technical help.
I have one and I really like it, does a great job, you need to fine the saniserv dealer closest to you for parts and supplys, they have everything you need.
Bob aviator state of Maine
Aug 31, 2009 | SaniServ 501 Twist 22 Quart Ice Cream...
I need a manual
Couldn't find a manual for you.
But i found a link to SaniServ to contact them for techincal support:
http://www.saniserv.com/contact.jsp?p_=&go=no&form=4
Hopefully they can tell you how to fix your machine.
Good Luck
Apr 16, 2008 | SaniServ 501 Twist 22 Quart Ice Cream...
What brand compressor do saniserv use
Depends on the unit, goto to www.saniserve.com ,they can tell you the exact compressor by the model and serial numbers.
Feb 26, 2008 | SaniServ 401 20 Quart Ice Cream Maker
Opertational Manual for SaniServ 401 1A (20 Quart)
I called:
A Service Provider
(305) 279-9544 Office
but don't tell sani-serv. They are anti-DIY and will politely try not to help you.
Oct 13, 2007 | SaniServ 401 20 Quart Ice Cream Maker
Ice Cream Makers Logo
308 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
