Question about Vacuums
Bissell 5990 vacuum cleaner brush does not turn
    Master:
  • Vacuums Master
  • 851 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Jul 30, 2017
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
SOURCE: Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Posted on Sep 28, 2008
  • 33 Answers
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Posted on Jan 18, 2009
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
Feb 16, 2011 | Bissell Upright Vacuum - The Pet Hair...
Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Jul 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Clean Shot brushes do not turn, belts in place.
heatman101
rgh
Apr 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL PROHEAT 2X 9200E - BRUSHES WON'T TURN
Hi there if u have already replaced the brush motor and the brushes stil aren't rotating, you wil need to also replace the circuit board that is located in the upper part of the machine after u take the 5 screws out the back, hope this helps, I repair bissells for a living so any problems email me, scottjones@rockfan.com
Apr 05, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
Sep 02, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
