Nutool 650w generator
Starts and runs for short time then wont re start for a while all connections ok and carb cleaned but still the same ant thoughts
SOURCE: Generator won't start
After removing the carb, disassembling and blowing it out (twice) to no avail, got a one gallon can of Gunk Parts and Carburetor dip. Removed the carburetor (again), removed float bowl cover, gasket, float, and needle valve and soaked it in the cleaner for several hours. Blew it out (again) and reinstalled it. Now generator starts on first pull like new!
Posted on Sep 14, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
SOURCE: in have a 1985 suzi gs550e it starts but only
I have an intermittent petcock problem with mine, check that. It has a vacuum switch in it that can stick
Posted on May 18, 2010
SOURCE: McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Posted on Jul 12, 2010
  • 3 Answers
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Posted on Jan 17, 2011
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
Carburetor problems. Generator won't start. Squrit gas in carb and it runs for short time.
check the filter and replace, you will need to remove the carb and clean the chamber out and the injector as this can block up due to build up of fuel deposits.
Jul 23, 2017 | Electrical Supplies
Powerback gt5250 generator starts but wont keep running
Are you sure the float level is OK? Is the fuel old? Is the air filter dirty?
Jul 04, 2014 | Electrical Supplies
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
Generator Won't start
Gap the plug at .030 What is most likely the main problem is whatever gas sat in the carb. Even with fresh gas there will be some old gas still in the float bowl. You may be able to drain the bowl and be OK but I have a feeling that the carb will need to come off and be disassembled and cleaned properly. You can try spraying carb cleaner (I dislike starting fluid as it is too volatile and carb cleaner does just as well in this instance) into the carb/intake. Remove the air filter, open the choke, and spray the carb cleaner in through that way if possible. You can actually keep an engine running by spraying with short bursts. Even by just spraying once you should be able to get the engine to start. If it does start but then will not stay running without spraying more into the engine then it is a carb problem.
Aug 24, 2012 | Coleman Powermate 6250 10hp Generator
Been stiiting for 6 months wont start?
Start by draining the fuel and cleaning the carb. Modern gas goes stale pretty fast and any gas over 90 days old is risky if you don't add a fuel stabilizer. You can remove the air filter and spray carb cleaner into the carb then try and start it. If it starts and runs for a second then the carb is dirty/plugged.
Jul 02, 2011 | Porter Cable 5,500 Watt Portable Generator...
Wont start. sprayed stater fluid but wont stay running
Your carb needs cleaned out. Tke it off and clean it out well with a good carb cleaner and you should be fine
Feb 06, 2010 | Briggs & Stratton Power Products 5,550...
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
My 6250 generator has been dormant for a few years. Worked well previously. Can't start it now. It will fire with stater fluid, but stall. Fuel line checked and ok. I think Carb. might have buildup that...
yes gas will deteriate and leave varnish deposits clogging carberator and layer in tank has yellowish color flush lines with brake cleaner and spray carb with spray carb cleaner and spray inside fuel inlet on carb let sit about 15 minutes redo and sit about 4 times clean fuel tank with brake cleaner (with tank off) until clean, refill with fresh gas and add about table spoon carb cleaner per quart of gas and let in run for awhile. when storing for any period of time add fuel stabilizer to avoid this issue in future
Jul 07, 2009 | Coleman Powermate Premium Plus 6250W...
Cranks fast but wont start
Hi, You did a good job of diagnosing your problem. Gas in bowl and dry plugs, starts with fluid, But, to quote you, "won't go through carb" . If you feel confident, you should disassemble and clean the carb, as that is going to be the problem. As a tip, if the genset is going to sit make sure to turn off the fuel flow to the engine and run till the engine dies. They do not like to sit any length of time with fuel in the carb. Good Luck, this should Fixya!
Mar 02, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
