Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door opener keypad keeps blinking What's your problem?
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
SOURCE: Need to reprogram keypad for garage door opener
On the rear of the g. door opener, there is a learn buttom.
The first step is to push this button in.
Then go to the remote and enter the new code you want
Press and hold the enter button.
The lights will blink and or you will hear two clicks.
The code you entered should be learned and ready to use
Posted on Sep 25, 2009
  • 3197 Answers
SOURCE: Chamberlain Garage Door opener model 3850.
The blinking lights are normal when you enter a code and press enter. I would try programming it and if that doesn't work replacing it. To program it you press and immediately release the smart/learn button on the rear of the motor unit and then key in your 4 digit code and press enter.
Posted on Dec 04, 2009
  • 8 Answers
SOURCE: I have a 2265R 1/2
Goto http://www.liftmaster.com/ConsumerWeb/products/productcompatibility.htm
and enter 2265 (leave out the R)
The learn button is RED and the antenna is GRAY
The 387LM Universal Keyless Entry is $49.99
http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=1267
The 977LM Wireless Keyless Entry System is $39.95
http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=1978
Posted on Feb 01, 2011
Wireless keypad won't accept our original code. Door won't open. When I enter the code the backlight on the keypad blinks rapidly. I need help. I have no other way to get in my...
Sounds like the receiver in your opener has quit working. Unless you break in you need to call a door technician. They can drill a hole in the door, use a special tool to pull the manual release and open the door. You should then have them install a keyed manual release if this ever happens again. They can also repair or replace your opener.
Jun 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener that wont work and the main opener in the garage keeps blinking how can i fix this?
If by "main opener" you mean the wall control is blinking, press and hold the lock button for 3 seconds.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
The button on wall which has a little green lite in the center, keeps blinking, but the garage door does open
Press and hold the lock button for 3 seconds to stop the light from blinking. That blinking is the indication that the lock function is on and your remotes will not work.
May 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
The opener inside the garage works when you push the button, but the remote outside the garage door just keeps blinking once you put in the code
what model. Did you code the outdoor keypad? Hit learn button and code the keypad. If done correctly, light bulbs on motor head will blink once or twice.
May 06, 2010 | Liftmaster, Chamberlain, Sears Door...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
287 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
