Question about Indesit W 123 Front Load Washer
WIL103 WAHING MACHINE
The door lock mechanism has been replaced it was considered faulty,when the programme is selected and ready the door led rapidly flashes and the machine does not run
  • martinmc47 Oct 22, 2008
    I have inspected it again,the symptoms are:from swich on at the mains tha 9hr led and the function leds light up then all go ouy after 2 seconds then the door /reset led rapidly flashes and the delay timer and stain remover leds slowlly flash,15 minutes later the later leds have gone out but door remains flashing rapidly
    just had a phone call right now and the machine has begun to work,i did think that may be the pcb might need replacing that was my next option,thanks for your help
    Scholar:
  • 121 Answers
Was your door latch the problem to begin with? If the latch is installed properly, then it sounds like a problem in control circuit. I don't see any model, but this could be door sensor, or a pc board. I hope this helps.
Posted on Oct 22, 2008
    Sergeant:
    Champion:
  • 331 Answers
The door led is flashing because the door has not been closed correctly...
if u have replaced the door maybe the door is not an exact fit ....
check if the door fits properly or not
    Scholar:
  • 136 Answers
Check wheather the mechanism which you have replaced is fitted properly as the orignal one.
  • ready2helpu Oct 22, 2008
    also check wheather the sensors are in proper position if they move a bit from its orignal position whilr replacing the mechanism this error could occur.
    if have an idea of replacing it yourself .remove that mechanism again and refit it properly.
    or call the technician who has done this for you before.
    its the fitting error so the led flashes and nothing happens.
    thanks.
    Genius:
  • 1,269 Answers
Try to power off you unit for about 5-10 minutes then plug it back in. Did the technician touch the control board?
  • Michael Galve
    Michael Galve Oct 22, 2008
    Unplug the power for about 10 minutes then plug it back in.
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
H
Apr 03, 2016 | Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
AWM6140/3 Wahing machine
it's a prgramme timer issue mate, you either need the timer flashing with updated software or a replacement timer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
255 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
