My mp3 4g 180 player does not h0ld the charge
Ive bl0wn a head gasket will b0tt0m end h0ld up with rec0n heads
It is not worth the cost of repairing. Its a junk yard buy now.
Jun 28, 2016 | Cars & Trucks
How do I charge my mp3 & video player?
Connect your charger to a powerpoint and then put the plug into the charging slot
Dec 20, 2015 | Eclipse 180 Pro 4GB* Video MP3 Player
Do I have to turn off the MP3 ECLIPSE to charge it
Best charge soaks in when the device is off, or you are just partially charging the battery which is not a good thing. Only Laptop's are designed to be charged while the device is on and running. Their adapters deliver high current .
May 01, 2011 | Mach Speed Eclipse 180 MP3 Player
My mp3 player wont turn on even when we charged it.
Are you sure it is charging? If the screen actually says charging and it is not then you more than likely have an internal issue with your MP3 player. You may want to try a new USB cord and also make sure the driver is updated first though. Good luck.
Mar 05, 2011 | Mach Speed Eclipse 180 MP3 Player
Sony nwz-b133f not working
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Sep 16, 2009 | Sony NWZB133F MP3 Player
Stuck on menu
Charge up the MP3 to the maximum and if it is still stuck press reset.
Aug 28, 2009 | Sony NWZ-B103FBLK MP3 Player
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
19 people viewed this question
 Grubhead
Grubhead
