Inside unit The control transformer blowed up when when water got on it from thawing out the coil after it froze over due to being low on coolant. I call a repair company and they installed the wired transformer backwards Where would i get a wiring diagram for a Intertherm heat pump Model#: E1EH-105HA SERIAL#: E1E9505-06625
How do you know it was installed backwards?
Posted on Mar 29, 2009
    New Friend:
  • 30 Answers
You can get one from an american supply near you. but you dont need one for a transformer. the istructions will be printed on the transformer. just put th high power where it is labeled and the low power on the other side. that is after you get a new one. also check to see if there is a fuse on the circuit board
Posted on Oct 30, 2008
Not freezing water pooling door shelves
sounds like coils froze up... in freezer about halfway down there is a panel. unplug fridge.. remove panel, use blow dryer to thaw coils. this will cause a lot of water to come out. once they are thawed out, replace panel, plug it back up and it should be fine... sounds like someone left it cracked open overnight.
Oct 25, 2013 | Frigidaire GLSZ28V8GW SIDE BY SIDE...
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
How can I thaw frozen heater coil hoses?
If your heater core hoses are frozen you should immediately drain the coolant out of your radiator and engine and refill it with the proper mixture. Your lucky if your heater core lines are the only thing that froze, it could have popped a freeze plug or two out of the block. You could use a hair dryer or heat gun if you need to unfreeze it quickly.
Jan 02, 2010 | 2005 Dodge Caravan
Indoor coils freezing up
You have a low refrigerant (leak) problem or poor airflow due to dirty coils or bad fan motor.
Maybe a combination of all 3.
Check the coils for dirt and lint. Check the fan motor blower wheel for lint on the blades. Check the condensing unit refrrigerant operating pressure. Low side for R22 should be approximately 68 psi, R410 pressure should be approximately 135 psi.
Sep 28, 2009 | Intertherm P3RA-048K Air Conditioner
Drinking water line at door frozen ,how to fix
Move the frozen food into the refrigerator side and turn off the freezer. Leave the door open to help it thaw quicker. A blow dryer helps to speed things up. When the line thaws, turn the freezer back on and move the frozen food back over. I am curious why it froze. Was the freezer temperature set too low or has anyone been inside the door to move the water line or insulation???
Sep 13, 2009 | GE GSS20IEP Side by Side Refrigerator
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Changed the compacitor unit ran fine for half a day..then would not blow cold air..so i let it thaw overnight turned it back onit was fine..then after 5 hours..back to not blowing cold air..any...
if you let it thaw it sounds like your coil froze up
a frozen coil is usually due to lack of air flow (a dirty air filter or bad blower motor) if both of these are ok then you probably are low on refrigerant
i would suggest finding someone who specializes in goodman or someone who is certified to handle refrigerant to check your refrigerant pressures
Jul 29, 2009 | Goodman CKL24AR24 Air Conditioner
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Furance Nordyne E!EB-015HA
If the transformer is you must have a low voltage short.
does your transformer have a trip switch that you can reset?
You could try to use a hair drier and dry out any water residu in the compartment. but my guess is you have a low voltage short.
May 18, 2008 | Heating & Cooling
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
