Question about True T-49 Side by Side Refrigerator Commercial
The pin came out of the spring loaded collet in the top door hinge of my True T 49, how do I rewind the spring and replace the pin?
The pin came out of the top hinge as the door closed, making quite a bang when the internal spring unloaded. I have the pin but I am unsure as to how to go about rewinding the spring and replacing the pin. The collet with the 4 holes which the pin fits into rotates against the spring tension but seems to not have any affect on the door. Bearing in mind that I can only rotate the collet about 1/4 of a turn, it may require several rotations to have enough tension to function properly.
3 Suggested Answers
refritech08
  • 149 Answers
SOURCE: RE: true T-49
check the hinge position it's probably off line
Posted on Aug 02, 2008
22yooper
  • 828 Answers
SOURCE: Door closer pin
You can make one or order one through "Coldparts.com" if the part is available individually.
Posted on May 09, 2008
How do I repair the door spring?
I believe you need to buy and install new door hinges.
Apr 21, 2015 | True T-49 Side by Side Refrigerator...
One of the doors will not close
The top hinge has a spring to close door. You can see a pin in a hole on top against a stop pin. Removing pin and winding up the hinge spring helps, find an Allen wrench that fits the other holes to assist. If winding one direction makes worse go the other direction. A new hinge may be in order. I can get you one if you need it. Wmontg5988@yahoo.com
Oct 27, 2013 | True T-49 Side by Side Refrigerator...
The auto-closure spring for the door appears to be broken. What is the best way to go about repairing it?
You need a new top hinge, call true at +1 800 325 6152 for part numbers and ordering info. They are very secretive about their info, they may or may not help. They may refer you to a local tech company. I can get the parts if you can't get anywhere with them.
Feb 11, 2013 | True GDM-26 Refrigerator
How to replace door spring T-49
very easy unless the old spring is blocked /or stopped for the foam insulation , you have to take both hinges and than with needle nose plplies pull it out , unless the FOAM STOPPED IT , than use different approuch you have to take the pannel off and cut around the spring . good luck,
Jul 19, 2012 | True T-49 Side by Side Refrigerator...
How do I replace the long screw that holds the door up on the door hinges,on a '97 gmc Sonoma?
I have done a 100 of these.
The hardest part is going to be to reinstall the spring on the lower hinge arm. this is not a screw but rather a pin.
There are two hinges that hold the door to body.
when the upper and lower pins are removed the door will come away from body, it is important that before you remove the pins you take a look at the hinges.
Pay close att. to the way the hinges sit inside each other and the way the pins go in. see if they go from top to bottom or from bottom to top. also note where the copper bushings sit in hinges. each hinge has one pin and two copper bushings top go into hinge.
Over time the pins and bushings wear out ,making door hard to open and close. When the pins and bushings get so bad that the bushing is worn out and then the pins are now wearing into the hinge hole itself then this get tricky. if hinge hole is egg shaped the new bushings will not last. the door will hang again in a few weeks. this is where is get costly, the hinges now need replacing. i have gotten good at welding the holes and filing them back to shape but this takes skill or hole will be wrong and bushing will not fit or line up.
Here is a youtube video to help you.
Take note. put jack stands under door with cloth to avoid scratching door.this is to hold door when pins are removed. have somone help you, they will hold door on stands. the wires will still run through door, pull door away from body a little to allow room to work.remove the spring, it will fall out as you remove pins, remove old bushings, clean hinge area and holes,next install new bushings, apply lube to holes for pins and on bushings, slide door back on frame hinges and install pins, next slide lock washers on pins to hold pins. last is the spring. you will need a spring tool, you may rent one at auto parts store. hope this helps good day.
Feb 26, 2012 | 1997 GMC Sonoma
Need instructions on replacing drivers side door hinge pins and bushings
  • 1. Place masking tape on the inside edges of the door, on both the inside and outside of the door. 2. Remove the door spring by using a door spring removal tool. Insert the tool into the door spring, turn the knob with a screwdriver to compress the spring, then pull out the tool. 3. Set a 5-gallon bucket under the door. This will help support the weight of the door. 4.Place a nail punch under the hinge pin, and strike it with a hammer. Repeat this until the hinge pin begins to come out of the hinge. 5.Place the end of a flat-head screwdriver under the top of the hinge pin, then strike the screwdriver with the hammer to force the hinge pin out of the hinge. 6. Place the bushing on top of the new door hinge pin, and tap it into place with the hammer. 7. Insert the new hinge pin into the hinge. Tap on the hinge pin with the hammer and nail punch to force the pin into the hinge. 8. Insert the hinge spring back into the door, and release the tension on the spring removal tool. 9. Spray the door hinge with a lubricating spray or apply grease.
    I know there are a few directions but it is fairly easy to do. If you have access to an air hammer and a compressor you can use this in place of a manual hammer to make the process a bit easier.
    Hope this helps.
  • Mar 10, 2011 | GMC Sierra 2500HD Cars & Trucks
    Can't get the oven door back on. it was sitting
    As you said they are spring loaded so be careful. You will need to pull on the hinge, which takes some muscle and you should see a small hole to put a pin or small screwdriver in to hold the hinge out. When this is in place on both the hinges you can put the door back on. This is the most common hinge style on Wpl or there may be tabs on the tops of the hinges to hold the hinge out. If the door still does not close all the way after getting the hinges all the way on you will need to take the door apart and replace the hinge/spring assy. Thanks for rating me after you read this.
    Dec 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Replacing the oven door to the Whirlpool electric range RF375PXE
    There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
    Jan 31, 2009 | Whirlpool Kitchen Ranges
    Door closer pin
    Apr 30, 2008 | True T-49 Side by Side Refrigerator...
    Whirlpool Microwave Door
    if spring loaded push the pin in firs then hook on spring
    Feb 12, 2007 | Whirlpool GH6178XPS Microwave Oven
    True T-49 Side by Side Refrigerator Commercial Logo
    55 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
