Question about Samsung Ezon Digital Door Lock
Where can I find a manual for a SHS DL 52 door lock?
Samsung shs 5120
Samsung phone seller can.
Jan 08, 2014 | Samsung Ezon Digital Door Lock
What is error dL f
Doorlock error.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
I have a service manual and more HERE
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not start, it beeps and say's dL / F
Door Lock Error---(F/DL)
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
This will essentially be the result of a failed door locking mechanism(wax motor failure). The necessary actions are to replace the entire door locking assembly. Click here to access the repair manual for your unit. This universal duet manual will guide you through the necessary testing procedure and component accessing, as well. Replacing the door locking mechanism will correct this issue.
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer says dl and then f
Potential Causes
Aug 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Ezon Digital Door Lock Logo
182 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
