Question about Panasonic TC-32LX50 32 in. HD-Ready LCD Television
Panasonic TC-32LX50 blinking red light
This was given to me, so I don't have anything invested in it or anything to lose by doing some component replacement myself. What is the problem and is there a sub-$100 fix for it. It powers on green then some clicking, then red, a bit more clicking and then blinking red light. Doesn't matter whether or no there is a video input (have tried both HDMI and Component) Thanks, Stewart
    Top Expert:
  • Panasonic Master
  • 36,580 Answers
Could be an open internal fuse or power supply failure
Posted on Jul 31, 2017
SOURCE: TC-32LX50
If you have Comcast, you need to buy an upgraded HDTV cable. (They are avail @ Sam's Club & Radio Shack.) Instead of a six port cable, get the two port. The cable's that Comcast provides are too cheap. Hopefully though, you've already gotten rid of the lines.
Posted on Nov 25, 2007
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
  • 1039 Answers
SOURCE: Grainy and red tint on component video inputs from
Usually when you have a red tint when using the component input i'ts because the wires are switched on one end or one of the 3 video wires is bad. See if blue and green are switched.I see this all the time. Is your picture grainy on all input?
Posted on Nov 22, 2009
tvtek
  • 1284 Answers
SOURCE: HDMI plugged in...get HD stations when put on HDMI
If you are connected to a cable box that is made by Scientific Atlanta you need to go into the settings and change audio output to HDMI. If it set to Dolby Digital it wont pass audio through the HDMI port.
  • 8457 Answers
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 06, 2010
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
The HD-TV screen stays on for 4 seconds then it
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 10, 2010 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
SHUTS OFF BUY IT SELF AFTER A FEW SECS.
sounds like a internal switch fault, its very common. a tv repair man should be able to fix it.
Dec 15, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
TC-32LX50
Oct 20, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
No video
yea since the tv was replaced you can call the same technician and let him repair the tv the problem is in the video section or related circuit.good luck.
Apr 16, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Panasonic TC-32LX50 32 in. HD-Ready LCD Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
