Question about Hotpoint WD62 Front Load Washer / Dryer
Lost jewellery in washer dryer
I have accidentally washed a necklace which was in the pocket of some trousers and it would seem it has slipped through the drum.
Is there any way of us retrieving this without completely ruining the appliance?
It is a Hotpoint WD62.po
  • 417 Answers
There is a chance you may be able to retrieve it from the fiter if you have one, if not, it may have gone into the pump drain. If you still have the user instruction booklet it may show you how to check this
If not you would need to either remove the lower front panel and then undo the twist cover or turn the machine onto its side and look for a round cap at the end of a stub hose near the pump casing this sometimes has a spring clip securing it around the hose from the pump.
Remove the cap and check if possible, if nothing there, also check the pump on the inlet side by removing the hose.
Remember to disconnect the washer from the electricity supply before attempting this also turn off the water valve.
Please remember to rate this solution.
Posted on Oct 22, 2008
How can I find my necklace in my dryer?
First check the lent catching screen and then the vent and hose and the ground below the vent exit. Completely clean those out. If you don't find the necklace in that process, turn the dryer on to see if it will eject the necklace into the vent hose. If it is trapped behind the drum, you should be able to hear it rattling around. However, dismantling the dryer can be dangerous so you should consider a hiring a dryer repairman to do that if it is necessary.
Jan 13, 2013 | Dryers
Can you tell me where i can find a fashionable necklace for my beautiful girlfriend?
Youcan buy if from your locial stores If you can't find a necklace which you want to buy. You also can search for website. There are many websites provide beautiful and fashionable necklaces.such as mubuy.com,.
Dec 25, 2012 | Washing Machines
Indesit wm12x not washing
see the causes and remedies: God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control panel.
Jul 18, 2012 | Washing Machines
Necklace has been washed in machine how do you find it
if it is enough big it must be stuck in the pipes but if it isn't then you should search it it the tank please rate my answer thank you : )
Aug 19, 2010 | Candy CNW156 Front Load Washer / Dryer
The washer seems to deposit stains on the clothes. No amount of stain remover seems to remove the stains.
just a though check inside the washer for things like paperclips,thumbtacks small pieces necklaces things like that get caught in those small drain holes and cause havoc
Apr 13, 2010 | Electrolux EW1000i Front Load Washer
Lost charm necklace in dryer. any way to retrieve
You would need to open up the machine to get inside. If yours is a Whirlpool (also Kenmore and other brands), this page explains how to do it. Once the cover is off, have a flashlight and a brush handy so you can sweep out built-up lint and look for your lost treasure.
Good luck and happy hunting!
Mar 01, 2010 | Dryers
Lost jewellery in washing machine
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Washing Machines
I've washed some jewellery in washing machine!!
You might be able to pop the very top off the agitater,unscrew the nut and pull it up,your jewels will be under it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Nov 11, 2008 | Indesit WA 125 Front Load Washer
Daughters necklace caught in washing bin holes
If you cut the chain what is left could possible work its way into drain pump. Jamming it.
Jul 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool ultimate care II lost item in washer or dryer
It is most likely that they are in the dryer if you still have not found them. Please respond with the type of dryer that you have and I should be able to assist you in opening your machine for a good look. From what you have describe it sounds like you have an Inglis or speed queen dryer.
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint WD62 Front Load Washer / Dryer Logo
131 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
