Question about Hoover Vacuums
Hoover the on-off switch could be the problem will start and stop by itself. model is u2440-900 series is zh12.0 1200.60hz 12.0.a this product is easy to handle havent had that long of course made in china
  • 414 Answers
A common problem with hoover vacuum cleaners is that a wire breaks inside the insulation just where the power cable enters the machine body causing the erratic on off situation you describe.
There is a connector box inside the body of the cleaner where the cable goes in and if you can get to this you need to check the wires for breaks you will need to pinch the insulatio as the break will not be visible as it is inside the insulation. if you find the broken wire it is a matter of cutting it back and re connecting.
Please remember to rate this article.
Posted on Oct 22, 2008
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
I was vacuuming with my Hoover Windtunnel Rewind t-series, and the vacuum simply stopped working. I plugged it into other outlets all around the house but no power suddenly.
Wait 30 minutes and try again, there is a thermal overload switch that resets itself.
Clean all three filters and see what happens.
Gary
Feb 23, 2011 | Hoover Vacuums
Where can i get a replacement water tank? for model # F5906-900 series 12?
The replacement parts can be ordered from hoover or through any hoover dealer. thier info can be found through the Hoover website. If you are unable to obtain a direct match, there may be available ones in different color.
Oct 24, 2009 | Hoover F5906-900 Upright Steam Vacuum
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
I have a hoover carpet cleaner model # F7427-900 series Z120 and the rotating brushes stopped moving. How do I fix this?
The brushe until needs to be snapped in very hard; to line up correctly. Pull the unti off and put it back in, good luck.
Jun 30, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
They just stopped working!
Hoover has a 1 year warranty on their vacuums, so the newer one will be under warranty. The other won't be. It could be bad switches, even tho they sound ok, they could still be bad, One side of the cord could be open, there is also a thermostat on the motors, it may have opened up, then of course could even be the motor. Just would have to be check over.
Jan 06, 2008 | Vacuums
Vacuums Logo
61 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
