Question about GE Washing Machines
GE Profile washer Model WPRE8150K2WT cycles are all messed up. Timer keeps resetting itself in regular wash cycles and seems to get stuck in the drain mode. Washer sometimes runs for 2 hours or more before we have to turn it off and put it on drian and spin.
  • Leah Feb 06, 2012
    Washer does drain the water out...just won't progress to the next step of spinning when in any of the wash modes. Or sometimes it will progress to the spin mode after draining the water and getting stuck for a long time ......only to have the spin cycle half *** spin the water out of the clothes. The only way we can get it to spin normally, is to put it in the drain and spin mode.
  • Leah Feb 19, 2012
    Thanks for the suggestions.....I've come to the conclusion that it is a piece of SH**. Am scrapping it and buying a speedqueen. Will NEVER buy anything GE again!
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
oscarn
  • 109 Answers
SOURCE: Whirlpool LGR7648KQ1 top loader washer
Hi It appears that- You have a clogged water pump inlet filter. Normally located at the bottom of the machine there should be a 1"-2" disk that you need to rotate half turn to release. Be aware that a large quantity of water is likely to drain when you open it. Good luck
Posted on Sep 07, 2007
  • 1294 Answers
SOURCE: ge profile won't drain
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 29, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
  • 5 Answers
SOURCE: ge washer is not agitating or spinning
change the timer.
Posted on May 28, 2009
GE Profile Model WPRE8150K2WT will not fill up with water. Just had Harness fuse Kit replaced two weeks ago as agitation and spin had stopped working. Washer worked for two weeks and now this problem with...
check the back of you machine there is a little sieve where the water comes sometimes it gets blocked with dirt just clean it if not that its the water valve its is to change
Jan 27, 2014 | GE Washing Machines
GE WASHER LIGHTS FLASHING BUT NOT WORKING
It won't change because the cycle was incomplete and the safety control is preventing a restart. Until you get professional onsite service; unplug the washer; make certain all of the water is drained out, and disconnect the hoses. Have someone help you tilt the washer forward and lay on the front side. Pick it up again and reach into the tub area and spin the tube around, and kind-of move it side to side. Hook it back up, plug it into the power supply and reset the timer to start a short wash. Try to start and see if you get any action. If after all of that; nothing changed, the timer on the circuit board is stuck where you left off when the unbalanced load shut it down.
Dec 23, 2013 | GE Profile WPRE6100G Top Load Washer
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
GE Washer keeps getting stuck in drain cycle
When you replace the timer before did you tighten up the connectors? and you can figure out your budget I can't $60.00 for a new timer or $1000.00 for a new one. if it lasted for a few years I could find a use for the money elsewhere. But if it has other probems then by all means replace the machine.
Aug 06, 2009 | GE WBSR3140DW Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Dec 13, 2007 | GE WBSE3120B Top Load Washer
GE Profile Washer
1) Most GE appliances have service manuals. By the manual because it will save you the repair services for the life of the machine. 2) I am not familiar with the GE Profile, so I don't know if it has dial knobs, or control panels. Any way, your problems seem like the timer unit is the problem. If it has dial knobs, the timer costs about US$100 - $150. The control panel circuit probably costs that much. You can buy the service manual and parts from Sears or parts services
Aug 19, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
137 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
