Question about Abit SL6 Motherboard
The computer fails to start
When I start feeding the motherboard starts the CPU fan turns hard disks and players running for 20 seconds then there is a short beep and the power to the motherboard stops before the post during that time was nothing on the screen
I have a problem on my motherboard that when i start cpu fan on hdd on but there is no dis play or any beep which tell that it star so it is the problem no dispay
Posted on Dec 29, 2008
  • 31 Answers
Try replace psu or ram
Posted on Oct 22, 2008
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Inspiron m5030 cpu fan start working but stop working in a few seconds
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Feb 10, 2013 | Dell Inspiron M5030 Laptop
Gigabyte H55M USB3 Buzzing/Beeping problem.
Hello here is the homepage.
http://www.gigabyte.com/products/product-page.aspx?pid=3444#dl
The most common problem is a fan that's failing, or a wire which is hitting the fan blades. There are usually 2 fans: one for the power supply and one for the CPU. If one of these fails completely, its dangerous -- the computer can overheat and basically burn up.
Another possibility is a failing hard drive (the bearings can make noise).
This could also be the graphic card fan failing, or the powersupply fan
( Bad bearings )
If so, it must be renewed.
Try also to blow the case out for dust, with compressed air. ( if any )
Especialy the cpu fan.
Good luck
Oct 13, 2012 | Gigabyte Giga Byte Technology Ga H55m Usb3...
My transcend 500 gb is not getting detected by laptop,power of hard disk automatically turns off after 30 seconds
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
hope this helps you
Mar 08, 2012 | Transcend StoreJet 320 GB USB 20 Hard...
No startup power
if a computer will not boot at all it is either the ram memory to blame ..and in this case it will start the fan but fail the boot and either make a beep or will restart and make a click noise...in a loop ..The action is to remove the ram and place back and see if it works with one module at the time ..This way you identify the wrong one ..
Another issue may be the CPU fan ..If it not starts..the computer will not work ..cause it is shut down due to overheating the CPU in seconds ..check the fan to work ..and to be plugged on the motherboard..if it seam not working change it ..
It may be a CPU failure..in this case it starts but nothing on screen but the fan spinning ..and makes no noise and do not let you do anything ..
If it does start ..and only shows a few devices but never boot up ..it may be the hard disk ..and in this case will tell you it failed to boot cause the hard disk is not functional ..or it will say it failed due to missing operation system ..
good luck ...the problem need to be taken one step at the time ..and eliminate causes...If you have another desktop and the devices match ..try them one by one ..and see what is working and what not ..
Dec 17, 2011 | Mirus Intel Celeron D 360 512MB RAM 80GB...
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
The pc did not turn on
It looks like your HDD or ROM has problem. Mostly your Hard Disk must have failed.
Apr 17, 2009 | Computers & Internet
Computer does not start
1. Check all the cable, RAM and than try.
2. Remove hard disk and CD-ROn & than try.
Apr 03, 2009 | HP (D7580-60003) Motherboard
CPU fan fail or speed too low
I bought the same motherboard this past year (used) and installed it with AMD Athlon 64 fx-57, Antec P180 case, 550 w power supply. I had the case cover off to check the fans when I first fired it up. The AMD oem cpu fan hesitated at power on for a few seconds, which worried me. It started spinning normally and I then shut the system down and waited a few minutes before restarting it. It spinned up fine so I put the cover back on. I started getting the same error you mentioned, so I updated the BIOS to 1013 version. That didn't solve the problem. I ended up disabling the warning in the BIOS as I got tired of seeing it, as I could see the fans were all spinning and the CPU temperature was at about 26 to 34 on cold boot.
I recently checked on this problem and seems many others with this board have this problem. One fellow said he mailed off a question the the problem to ASUStek and they replied that it is just a glitch, that the fan is "smarter" than the BIOS, as it will hesitate to spin fully at start up if the CPU is cool. The suggestion was to disable "Q Fan Controller" in BIOS. I did and don't get that warning.
As for the yellow question marks under manage in Windows, you need to install the drivers for all of those devices, and they will be on the disk that came with the motherboard. I use the latest drivers from the ASUS site, but the only one I couldn't install was the ACPI ATK 0110 Virtual Device that came out in 2007. When I try to unpack the .rar file it says Corrupt Headers and refuses to use the driver from that file. So, I use the driver from the disk.
Apr 12, 2007 | ASUS A8N-E Motherboard
Abit SL6 Motherboard Logo
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
