Question about Sharp XR-32X Projector
I have white and black dots that are in the picture we replaced the bulb but didnt take care of the problem any suggestions
  • Carla Feb 09, 2012
    it started out with a couple of dots now are millions of dots all over. The dots are even seen up on the ceiling. Some dots blink on and off while others are just stationary. It is really getting hard to see the picture. Any suggestions would be greatly appreciated
My lg325 projector when switched on shows power and ready light but lamp
does not come on. if i press the power switch again the lamp comes on with
3 dotted lines.
Posted on Aug 13, 2012
Black and white pixels in picture
The DLP chip is failing. The only way to fix the "dots" is to replace the DMD (digital mirror device) chip. Overheating causes this starfield effect to occur. See youtube video for explaination.
Home IPS LaserExpress
Dec 27, 2013 | Dell M210X DLP Projector
Black and white pixels increasing in number in my picture
The DMD chip is failing on your projection device. The only way to fix it is to replace the chip. The dots are usually caused by excessive heat build up.
http://www.youtube.com/watch?v=BYJTF3yZYVY
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
I am getting white spots that are appearing on the display image. It started out with one but now there's more every day. Is this fixable? Is there dust maybe ibside the lens? Is the bulb going? The...
I feel Most of DLP's getting this issue. Please tell me If the black & white dots are blinking....
To see it you need to put very clearly focused A4 sheet. If some dots are blinking .... most of time DLP chip is bad or getting bad.. IF can please upload a very clear picture......
Jul 30, 2011 | Optoma DLP Projector Multimedia Projector
How do you change a low beam headlight bulb on a 2008 Buick Allure?
I actually did change my low beam bulb with ease. I took pictures to help with step by step procedures.
Step 1.
Step 2.
Step 3.
Remove the red dotted plastic plugs out. So you have wiggle room.
Once removed all the red dots, where the green dots are you can gently lift it past it, and pull it towards the front away from the engine.
Step 4.
Find the white latch and pull it up to the little square:
This you will see if you have pulled to far up, it has to match up with the little white square.
Step 5.
Black Latch, pull it up just the same way for the white latch, but you will need to unscrew the lock screw.
Step 6.
The light bulb port has to be turned clockwise to unscrew, opposite to lock back it in again.
Step 7.
Once done it should like this, and you will need to a flat screw driver to pop the little clips on the side of the holder and replace bulb.
Step 8, put everything back together and you are done.
Nov 09, 2010 | Buick LaCrosse Cars & Trucks
My InFocus IN76 just started displaying yellow and white dots.
are the dots pixelated or blurred? if they are pixelated, you have a dmd chip issue and will have to replace the whole optical engine. if they are blurred, it is an optics problem, most likely the colorwheel. that can be replaced individually. you can get parts from an infocus service center or send it in to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 18, 2010 | InFocus Office Equipment & Supplies
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Projects in black and white
It's probably the color-wheel problem. Maybe the color-wheel stucked because of dust and/or color-wheel sensor is covered with dust.
The simple way to check this, without reinstalling drivers or so, you just tap menu button on remote. If you will see only black-white user interface it is definitly color-wheel.
Good luck.
Nov 04, 2008 | Optoma H30 Multimedia Projector
No picture white screen
check you bulb and your color wheel notorious on this set
Nov 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Sharp XR-32X Projector Logo
486 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
