Question about Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W...
Idle control inop
#1 - idle control (demand sensing circuit wont decrease rpm to idle with no load)
#2 - engine kill switch inop
  • tom1652 Nov 23, 2008
    Same problem - kill switch does not work - no load idle does not work -
    engine hunts periodically.
    Any ideas? My guess is the circuit board which runs about $175.
  • 32 Answers
Check the small relays first, lightly tapping on them wile on may tell you the one that is bad but not all ways , if thats not it,Pull the circuit board and test or have a old tv repairman test the Diode's/resistor's on the board, if you find a bad one and do not know how to read the rating, take a digital close up picture of it and email it to one of many people selling diodes or resistor's on Ebay, buy it , solder it in.
Posted on Feb 05, 2009
C0899 U1026 U1064 P0300 P0506 P0446
Best Manuals I don't know abut your model but i'm sure this lady here can help you
Oct 26, 2017 | Cars & Trucks
It starts but as soon as it's put into gear acts like it wants to go but quits.
Could be a few things. But here are the obvious. Check for a vacuum leak around the intake. When you put the car into drive it starts putting strain on the engine, a vacuum leak will give it too much oxygen and cause a fuel mixture issue / reading.
If nothing wrong there, you may have a bad throttle position sensor. When you put the car into drive and it starts putting strain on the engine it will pull the idle down then the sensor will adjust it automatically. Hope this helps.
Mar 18, 2015 | 2000 Chevrolet Blazer
Correct code P0504?
What Colorado do you have ? 2 wheel or 4 wheel drive ? Sport ,sport LS 3.5L , Z71, Z71 LS. etc. what size engine ? an does it have electronic throttle control ? I have factory service info an it is not showing that code .
DTC P0506
Circuit Description
The throttle actuator control (TAC) motor is controlled by the powertrain control module (PCM). The DC motor located in the throttle body drives the throttle plate. In order to decrease idle speed, the PCM commands the throttle closed reducing air flow into the engine and the idle speed decreases. In order to increase idle speed, the PCM commands the throttle plate open allowing more air to pass the throttle plate. If the actual idle RPM does not match the desired idle RPM within a calibrated time, this DTC sets.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0506 Idle Speed Low
DTC P0507
Circuit Description
DTC Descriptor
DTC P0507 Idle Speed High
Cleaning the throttle body mite take care of it !
Cleaning Cleaning An Electronic Throttle Body Safely
Jan 31, 2015 | 2005 Chevrolet Colorado
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
P1646 how much to repair
P1796 Automatic Transmission
as you can no such code exists for a jaguar ,contact code reader manufacturer
Jan 03, 2011 | 2004 Jaguar S Type
2003 Yukon Denali XLT lights flicker, rpm goes up and down when on park or stopped or driving and slow speeds. Sometimes it turns off. I thought it might be bad spark plugs or cables so I changed them and...
Your vehicle has electronic throttle control . Position sensor's in the gas pedal an the throttle body , inputs to the Throttle Actuator Control Module
The TAC module is the control center for the throttle actuator control system. The TAC system is self-diagnosing and provides diagnostic information to the PCM through a dedicated serial data line. The TAC achieves throttle positioning by providing a pulse width modulated voltage to the TAC as directed by the PCM.
The throttle actuator control (TAC) system delivers improved throttle response and greater reliability and eliminates the need for mechanical cable. The TAC system performs the following functions:
• Accelerator pedal position sensing
• Throttle positioning to meet driver and engine demands
• Throttle position sensing
• Internal diagnostics
• Cruise control functions
• Manage TAC electrical power consumption
The TAC system components include the following:
• The accelerator pedal position (APP) sensors
• The throttle body assembly
• The throttle actuator control module
• The powertrain control module (PCM)
Accelerator Pedal Position (APP) Sensor
The accelerator pedal assembly contains 2 individual APP sensors within the assembly. The accelerator pedal position (APP) sensors 1 and 2 potentiometer type sensors each with 3 circuits:
• A 5-volt reference circuit
• A low reference circuit
• A signal circuit
The APP sensors are used to determine the pedal angle. The control module provides each APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensors then provide the control module with signal voltage proportional to pedal movement. APP sensor 1 signal voltage is low at the rest position and increases as the accelerator pedal is applied. APP sensor 2 signal voltage is high at the rest position and decreases as the accelerator is applied.
Throttle Body Assembly
The throttle body assembly consists of the throttle body, the throttle position (TP) sensors, and the throttle actuator motor. The throttle body functions similar to a similar to a conventional throttle body with the following exceptions:
• An electric motor opens and closes the throttle valve.
• The throttle blade is spring loaded in both directions and the default position is slightly open.
• There are 2 individual TP sensors within the throttle body assembly.
The TP sensors 1 and 2 are potentiometer type sensors each with 3 circuits:
• A signal circuit
The TP sensors are used to determine the throttle plate angle. The control module provides each TP sensor a 5-volt reference circuit and a low reference circuit. The TP sensors then provide the control module with signal voltage proportional to throttle plate movement. Both TP sensor signal voltages are low at closed throttle and increase as the throttle opens.
Flickering light's could be caused by a bad diode in the alternator . Fluctuating idle could be caused same alternator problem or dirty throttle plate.
Throttle Body Cleaning To Restore Idle Quality
Jul 15, 2017 | 2003 GMC Yukon
Diagnostic codes p1505 p1507 ran stalled wont run turns over fine
sorry but their are no diadnostic codes with this number in the manufacturers codes i have
P0505....Idle Control System
P0507....Idle Control System RPM Higher Than Expected
but i have found these generic codes for you if they help
Aug 10, 2010 | 2003 Hyundai Tiburon
1993 Toyota Paseo - Engine dies when clutch depressed
Absolutly, Your idle control valve at the end of your fuel rail has a vacuum line and its sensitive to pressure changes. One way to double check that would be to hook everything up normally and pull that vacuum line off your idle control valve. Are the symptoms the same?
Jun 04, 2009 | 1993 Toyota Paseo
I have 3 codes that showed up in the computer of my 1995 Ford Windstar
Here is the first half of the codes look till you find the one you have
111 System PASS.
112 ACT sensor circuit grounded.
113 ACT sensor circuit open.
114 ACT sensor is out of Self-Test.
116 ECT sensor is out of Self-Test.
117 ECT sensor circuit grounded.
118 ECT sensor circuit open.
121 TP sensor is out of Self-Test.
122 TP sensor input is less than Self-Test minimum.
123 TP sensor input is greater than Self-Test maximum.
124 TP sensor input voltage is greater than expected.
125 TP sensor input voltage is less than expected.
128 MAP vacuum hose damaged or disconnected.
129 Insufficient MAF input.
136 HEGO sensor circuit indicates system lean (Right HEGO).
137 HEGO sensor circuit indicates system rich (Right HEGO).
139 No HEGO switching (Front Side).
141 Fuel system indicates lean.
144 No HEGO switching (Left Side).
157 MAF sensor circuit open.
158 MAF sensor shorted to power.
159 MAF sensor is out of Self-Test.
167 Insufficient TP input change.
171 Lack of HEGO switching (Rear Side).
172 HEGO sensor circuit indicates lean. (Rear Side).
173 HEGO sensor circuit indicates rich. (Rear Side).
174 Check for diluted engine oil.
175 Lack of HEGO switching (Front Side).
176 HEGO sensor circuit indicates lean. (Front Side).
177 HEGO sensor circuit indicates rich. (Front Side).
178 Check for diluted engine oil.
179 Fuel system at part throttle lean adaptive limit, system rich (Rear Side).
181 Fuel system at part throttle rich adaptive limit, system lean (Rear Side).
182 Fuel system at idle lean adaptive limit, system rich (Rear Side).
183 Fuel system at idle rich adaptive limit, system lean (Rear Side).
184 MAF sensor input voltage is greater than expected, in range.
185 MAF sensor input voltage is less than expected, in range.
186 Closed loop injector pulse width longer than expected.
187 Closed loop injector pulse width shorter than expected.
188 Fuel system at part throttle lean adaptive limit, system rich (Front Side).
189 Fuel system at part throttle rich adaptive limit, system lean (Front Side).
193 Flexible Fuel sensor circuit failure.
211 PIP circuit failure.
212 Loss of tachometer/IDM input.
213 EEC SPOUT circuit open.
214 CID circuit failure.
215 PCM detected coil 1 primary circuit failure.
216 PCM detected coil 2 primary circuit failure.
217 PCM detected coil 3 primary circuit failure.
218 Loss of ignition diagnostic monitor signal-left side.
219 Spark timing defaulted to 10 degrees, spark output circuit open.
221 Spark timing error.
222 Loss of ignition diagnostic monitor signal-right side.
223 Loss of dual plug inhibit control.
224 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
225 Knock not sensed during dynamic response test KOER.
226 Ignition diagnostic monitor signal not received.
232 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
238 PCM detected coil 4 primary circuit failure.
241 Ignition control module to PCM ignition diagnostic monitor pulse width transmission error.
244 Cylinder Identification circuit fault present when cylinder balance test requested.
311 Secondary air injection system inoperative during KOER self-test (bank #1).
312 Secondary air injection system misdirected during KOER self-test.
313 Secondary air injection system not bypassed during KOER self-test.
314 Secondary air injection system inoperative during KOER self-test (bank #2)
326 PFE sensor circuit voltage lower than expected.
327 PFE sensor circuit voltage below Self-Test minimum.
328 Exhaust gas recirculation valve position sensor closed voltage lower than expected.
332 Insufficient EGR flow.
334 Exhaust gas recirculation valve position sensor closed voltage higher than expected.
335 PFE sensor circuit voltage out of Self-Test range.
336 PFE sensor circuit voltage higher than expected.
337 PFE sensor circuit voltage above Self-Test maximum.
338 Engine coolant temperature lower than expected (thermostat test).
339 Engine coolant temperature higher than expected (thermostat test).
341 Octane adjust service pin open.
381 Frequent A/C clutch cycling.
411 Cannot control RPM during KOER low RPM check.
412 Cannot control RPM during KOER high RPM check.
415 Idle Air Control system at maximum adaptive lower limit.
416 Idle Air Control system at upper adaptive learning limit.
452 Insufficient input from VSS.
453 Servo leaking down.
454 Servo leaking.
455 Insufficient RPM increase.
456 Insufficient RPM decrease.
457 Speed control command switch(s) circuit not functioning.
458 Speed control command switch(s) stuck/circuit grounded.
459 Speed control ground circuit open.
Jan 15, 2009 | 2001 Ford Windstar
Xterra repair
Since this is an intermittent problem, first try to determine if the problem arises due to one of these many intermittent problems:
* Vehicle vibration
* Heat sensitive
* Freezing
* Water intrusion
* Electrical load
* Cold or hot start up
If you can't isolate the cause of the intermittent problem, you can try adjusting the Idle Speed/Ignition Timing/Idle Mixture Ratio:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
PREPARATION
1) Make sure that the following parts are in good order.
* Battery
* Ignition system
* Engine oil and coolant levels
* Fuses
* ECM harness connector
* Vacuum hoses
* Air intake system
* (Oil filler cap, oil level gauge, etc.)
* Fuel pressure
* Engine compression
* EGR valve operation (If so equipped)
* Throttle valve
* Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
INSPECTION PROCEDURE
1 INSPECTION START
1. Visually check the following:
I Air cleaner clogging
I Hoses and ducts for leaks
I EGR valve operation (If so equipped)
I Electrical connectors
I Gasket
I Throttle valve and throttle position sensor operation
2. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
Ensure engine stays below 1,000 rpm.
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
4. Perform diagnostic test mode II (Self-diagnostic results).
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
3. Turn off engine and disconnect throttle position sensor harness connector.
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
' GO TO 2.
4 CHECK BASE IDLE SPEED
1. Check idle speed.
700±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
5 ADJUST BASE IDLE SPEED
1. Rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
' GO TO 6.
6 CHECK TARGET IDLE SPEED
1. Turn off engine and connect throttle position sensor harness connector.
2. Start and rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run at idle speed.
3. Check idle speed.
750±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 9.
NG ' GO TO 7.
7 DETECT MALFUNCTIONING PART
Check the following.
1. Check IACV-AAC valve and replace if necessary.
2. Check IACV-AAC valve harness and repair if necessary.
3. Check ECM function by substituting another known good ECM.
(ECM may be the cause of a problem, but this is rarely the case.)
' GO TO 9.
9 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
2. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
3. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 12.
NG (MIL does not blink.) ' GO TO 17.
NG (MIL blinks less than 5 times.)
' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
10 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
1. Warm engine to normal operating temperature.
2. Run engine at approx. 2000 rpm for approx. 2 minutes under no-load.
3. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
4. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 13.
NG ' GO TO 11.
11 DETECT MALFUNCTIONING PART
1. Check fuel pressure regulator.
2. Check mass air flow sensor and its circuit.
3. Check injector and its circuit.
Clean or replace if necessary.
4. Check engine coolant temperature sensor and its circuit.
5. Check ECM function by substituting another known good ECM.
' GO TO 2.
13 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
1. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
2. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' INSPECTION END
NG (MIL does not blink.) ' GO TO 16.
' 1. Replace front heated oxygen sensor RH.
2. GO TO 14.
14 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
3. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
OK or NG
OK ' INSPECTION END
NG ' GO TO 15.
15 DETECT MALFUNCTIONING PART
3. Check injector and its circuit. Clean or replace if necessary.
' GO TO 2.
16 CHECK FRONT HEATED OXYGEN SENSOR RH HARNESS
1. Turn off engine and disconnect battery ground cable.
2. Disconnect ECM harness connector.
3. Disconnect front heated oxygen sensor RH harness connector.
4. Check harness continuity between ECM terminal 50 and front heated oxygen sensor RH harness connector.
Continuity should exist.
OK or NG
OK ' 1. Connect ECM harness connector.
2. GO TO 18.
NG ' 1. Repair or replace harness.
2. GO TO 9.
17 CHECK FRONT HEATED OXYGEN SENSOR LH HARNESS
3. Disconnect front heated oxygen sensor LH harness connector.
4. Check harness continuity between ECM terminal 51 and front heated oxygen sensor LH harness connector.
OK or NG
2. GO TO 18.
2. GO TO 9.
18 PREPARATION FOR “CO” % CHECK
1. Disconnect engine coolant temperature sensor harness connector.
2. Connect a resistor (4.4 kW) between terminals of engine coolant temperature sensor harness connector.
' GO TO 19.
19 CHECK “CO” %
1. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
3. Check “CO” %.
Idle CO: 1.5 - 9%
After checking CO%,
a. Disconnect the resistor from terminals of engine coolant temperature sensor.
b. Connect engine coolant temperature sensor harness connector to engine coolant temperature sensor.
OK or NG
OK ' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
NG ' GO TO 20.
20 DETECT MALFUNCTIONING PART
1. Connect front heated oxygen sensor harness connectors to front heated oxygen sensors.
2. Check fuel pressure regulator.
3. Check mass air flow sensor and its circuit.
4. Check injector and its circuit.
5. Check engine coolant temperature sensor and its circuit.
6. Check ECM function by substituting another known good ECM.
' GO TO 2.
Aug 17, 2008 | 2000 Nissan Xterra
Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W... Logo
295 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
