Question about Radio Communications
How can I change the channel on a Motorola Radius M100?
  • Robin Feb 06, 2012
    I have a M100 NOT a M1225.
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Motorola Radius CM 300
The CM300 is programmable using Motorola propietary software, cable and RIB (radio interface box). The software is primarily available to Motorola dealers. The easiest way to have the radio programmed is to take or send your mobile radio to a dealer. Typically programming is around $25 for this unit.
If you provide the model number, it would be possible to give you more information about your radio. It can be VHF or UHF, 25, 40 or 45 watt. You could also google the model number. The model number begins with AAM50...
Posted on Jan 19, 2009
eradiostore
  • 1654 Answers
SOURCE: Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
Posted on May 01, 2009
eradiostore
  • 1654 Answers
SOURCE: How to program
The M1225 mobile is Motorola dealer programmable using the appropriate Motorola software, radio interface box (RIB) and programming cable. The cost for this type of programming is generally $15-$25.
Posted on May 30, 2009
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
What version of software (CPS) is needed to program the Motorola AXU4100 portable radio?
RVN4196 CPS (Motorola proprietary software subscription) which also does the Radius CP125.
Sep 30, 2009 | Motorola AXU4100 (10 Channels) 2-Way Radio
How to program
May 30, 2009 | Motorola Radio Communications
May 01, 2009 | Radio Communications
MOTOROLA RADIUS GP900
Unprogrammed channels will have a constant tone. It is possible your radio is unprogrammed. A dead battery tone is only for a moment, and is usually a medium tone then a low tone, sounding somewhat like beeedeeep.
Dec 06, 2008 | Radio Communications
Motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
Jul 05, 2008 | Motorola Talkabout FR50 (14 Channels)...
Radio Communications Logo
73 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
