Question about Fuji FinePix S8000fd Digital Camera
Fuji Finepix S800fd Power problems - No power
Yesterday I put a 12V DV charger into my 6V fuji S800fd camera. After that I left it without turning on an today I turned it on and there was no response, the LED light at the top has powered on a few times but no response on the LCD or viewfinder Please Help!
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
SOURCE: fuji finepix a400 focus error
Hi
I have the same camera and have devised this solution. Remove batteries, leave for about 10 mins then replace batteries ( make sure they are in good condition, Cover the aperture whilst switching it on and it should work - mine did on the 2nd attempt.
Good Luck
Posted on Aug 14, 2008
informatica
  • 1114 Answers
SOURCE: manual Fuji Finepix S8000fd
Hi - You can download the manual from the link underlined in blue below:
Finepix S8000fd
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 19, 2008
Steve5
  • 423 Answers
SOURCE: Fuji Finepix S9600 - Photography mode doesn't work
Sounds like the CCD (main image sensor) is dead. It should be covered under warranty. It doesn't sound like there is anything you've done, or can do to rectify it. Get it in to a Fuji service center with your warranty/receipts.
Posted on Sep 27, 2009
Testimonial: "Thanks, Steve. I took it to an authorized service center and the CCD sensor was indeed dead. Warranty covered! Thanks again!"
fathitkf
  • 1871 Answers
SOURCE: Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
Posted on Apr 11, 2010
How to charge fuji f455 camera
Either put the camera into the docking cradle and connect to a powered USB port, or take the battery out of the camera and put it into a compatible charger.
Aug 27, 2012 | Fuji FinePix F455 Digital Camera
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
I have a fuji finepix z10 and it wont turn on.
It needs to be connected to a computer port or a powered hub. Are you doing that?
Aug 21, 2009 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Aug 25, 2008 | Fuji FinePix F700 Digital Camera
Fuji FinePix S3100 will not turn on.
Sorry, no real solution. My friends have one that would not turn on and they left it without batteries for a month, then put the batteries in and it worked. Mine has failed and will not turn on. I have left the batteries out but nothing has miraculously fixed itself yet. May have to send it in to Fuji.
Apr 29, 2008 | Fuji FinePix S3100 Digital Camera
Fuji Finepix S3500 Wont Power Up
As another solution suggests , put new batteries in the camera and leave for an hour or so, I guess to recharge the internal memory battery
Sep 23, 2007 | Fuji FinePix S3500 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Fuji FinePix S8000fd Digital Camera Logo
123 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
