I had to lay the sweeper down as if I were going to sweep under a bed then on the top of the sweeper on either side is a screw, Mine had dirt in there so I didn't see them. Unscrew but don't remove the screws and then lift the cover off. You can down load a manual for free at the Eureka site http://www.eureka.com/customer-service
Try taking the upholstery nozzle apart, there are only a couple of screws, and make sure the little tube is attached where it is supposed to be attached. Be careful when you take it apart, and remember how to put it back together. Try running some water in the one end and see if it comes out the other end. I had a problem with the grip switch not working, and ended getting Eureka to send me a whole new unit as it was still under warranty. I honestly tried to fix it myself, but I don't think the design is good enough to be fixed, so replacement is usually the better choice. Again, I say, shame on Eureka for such a bad product. A good appliance service depot should be able to get a new hose for you, but if you have to pay big bucks, I think it is better to try a different brand than Eureka. I'm assuming by your question that the nozzle is the one on the upholstery hose attachment.
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
my question is actually about a hand held enviro-steamer called Big Shot
