Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Maytag Dishwasher Model MBD7601AWS won't start
KevinWhite
  • 1902 Answers
SOURCE: My maytag dishwasher won"t start
Hello & Welcome to FixYa
First clean the drain filter pump assembly located inside the front bottom access panel. If the problem is still there after cleaning the drain filter assembly then it means the control board is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 14, 2011
binghampaul
  • 23 Answers
SOURCE: My Maytag QuietSeries 400 dishwasher won't
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Posted on Jun 19, 2011
Daniel S
  • 4323 Answers
SOURCE: Maytag dishwasher MDBH985AWS1 won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
heatman101
  • 43501 Answers
SOURCE: I have a maytag dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Aug 05, 2011
mc1bean
  • 3053 Answers
SOURCE: My maytag dishwasher panel selections are all
Hello, deb
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Maytag dishwasher Model MDB7749AWB won't start/respond
Either the start switch, the start relay, the wires between them, the wires to the motor, or an internal fuse inside the panel, or the door safety interlock could be the problem. Even, any combination of the above could cause this. This is a real troubleshooting problem. Are you game?
Dec 28, 2012 | Dishwashers
Maytag dishwasher won't start but other buttons work
It's probably your Circuit Board (CB)! My dishwasher is on the second CB and it keeps blowing the dispenser transistor. This needs to be brought up to the MAYTAG goons to see if they will start recalling this crappy thing. My machine is barely a year old and will have it's third CB!
Jun 23, 2012 | Maytag MDB7749AWM Builtin Dishwasher
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
My dishwasher won't start at all
There could a number of reasons why it won't start but start with the locking mechanism first. Make sure the locking mechanism is in the "Locked" position. It will be the lever at the top of the door. If that isn't the problem try describing everything you have tried and post your question again.
Jan 20, 2012 | Maytag Dishwasher
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Hi
Daniel
Jun 19, 2011 | Maytag Dishwasher
My dishwasher won't pump out. I've cleaned filter and cleared line. still won't pump
heatman101
May 09, 2011 | Maytag Dishwashers
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
49 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
