My acer aspire one netbook D260-2380 will not boot. When I turn it on it takes me to this screen that says Windows boot manager
SOURCE: Downloading skype onto my acer aspire one netbook
For aspire one you need to download the Fedora 7 package from the Skype Website.
Afterwards, just do what your aspire asks you to do. When everything is installed, just press alt+F2, type in "skype", en press "Run". Skype will start up. That's it
SOURCE: i dropped my acer aspire one netbook and now it
check your RAM and hard drive to make sure they are still inplace. they may have been damaged when you dropped it
SOURCE: how can I install win
GO TO BIOS & CHANGE HARD DISK MODE AHCI mode to IDE mode. THEN TRY
IF PROBLEM NOT SOLVE PLEASE TELL ME.
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Testimonial: "my problem was solved thank you very much"
SOURCE: Hi, my acer aspire one
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
