Question about Watches
I have a Sekonda Titanium Model 3057 and have lost the battery. Please advise what battery I need.
My sekonda watch is losing 20 minutes or so a day but if I don't correct the watch it carries on as normal running 20 minutes behind if I correct it the next day 20 minutes are lost
Firstly, have you tried changing the battery?
Secondly, have you tried setting it 20 minutes ahead, to see if it rectifies itself over a day or so? It may be that the mechanism has gotten a little sticky.
May 19, 2017 | The Watches
Sekonda ladies watch model 4836 battery type please?
Take the watch to a jeweler who will open it, identify the type, and perhaps replace it.
Apr 30, 2017 | Watches
I've lost the instructions and can not reset it
Mate I googled the sekonda web site and this is the link-->
http://www.sekonda.co.uk/index.php?fuseaction=Static.faq
It's on the frequently asked questions page and if you click on the 10th question down (How do I use and adjust my Sekonda watch) a message drops down saying click HERE to download the sekonda instruction manual..... I hope this helps......CHEERS..
Mar 12, 2016 | Watches
What is the battery specification/type/spec for the Sekonda 3101 Men's writwatch
The practical answer is to take your watch to a jeweler who will not only open it but probably will install a replacement battery for a reasonable charge.
Mar 19, 2015 | Watches
Operating instructions for a Sekonda 3850
Let the 3 buttons on the left hand side be labelled A, B and C from top to bottom.
Hold C for 3 second until it beeps and display flashed.
Press B to move to whatever you need changing (e.g. hour, day, area)
Press A to change.
Press B to move to the next thing to change or press C once to exit.
May 28, 2012 | Watches
I have a Skagen 233xIttn Titanium gents watch and have lost the round back plate, is it possible to get a replacement one please
This back must be ordered from the manufacturer, there are no generic backs. Skagen customer service 1-877-752-4361 or email questions@skagendesigns.com I hope this helps, please have model number ready!
Sep 20, 2011 | Skagen 233xlttn Titanium Watch for Men
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Jan 22, 2010 | Watches
Sekonda 3850 battery replacement
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Aug 20, 2008 | Watches
Watches Logo
82 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
