Just started geting connection timeout issues with sites that I have been to lots of times. It worked one day and just didn't work the next. Anyone experiencing the same thing. Anyone have a fix for this. I have tried to access these sites from three different laptops using both IE and Firefox and none are able to gain access.
Here is a link from verizon and it will show all info how to trouble shoot
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj72JGSiZTXAhVD5IMKHV-6BUAQFggqMAA&url=https%3A%2F%2Fwww.verizon.com%2Fsupport%2Fresidential%2Finternet%2Fhighspeed%2Fnetworking%2Ftroubleshooting%2Fquestionsone%2F98979.htm&usg=AOvVaw2nnA9NPP1XyYUMmlW3efXa
SOURCE: Nonexistant customer service by Actiontec
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
SOURCE: Cant configure the router on my Actiontec gt724wgr
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
SOURCE: NO PSN with Actiontec GT704WG Verizon
If you can access the internet it is not a problem with the router. Are you able to access the PSN site but rejected when you enter your credentials?
SOURCE: my actiontec gt724wgr wont connect to the internet
go to folowing link you will have your internet
http://www.actiontec.com/support/product_details.php?pid=73
SOURCE: i cant acess my actiontec gt724wgr gateway login
No there isn`t. Try to reset the router with the little hidden 'Reset' button on the back(just push it once and hold it that way until the indicator lights change) and try again. If it`s still not working, you`ll have to change your computers IP address to 192.168.0.X (X = 2-255).Control
Panel > Network and Sharing > Change adapter settings(on the
upper left side), right click on the adapter and select properties.
Highlight the Internet Protocol version 4 and click Properties. After your done setting it up change the settings back to 'Automatic'.
Good luck
I have also faced
the same issues which you are facing and my friend told me about "ijinni
technician". I contacted them at www. ijinni. Com. For any issues just
open the website and you can chat with the experts who are Microsoft certified
technicians and will fix the issue itself on the spot or u can call them
through Skype. For more visit their website as it is very user friendly
website. Just click on the chat as the response rate will be very fast from
them and they have fixed my issues in no time.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat
where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just click
on skype icon on "ijinni.com" to make a free call.
3. You can email at [email protected]
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call
IJINNI
