Have sound no picture
Hi, I have a Samsung SP-54T6HP Projection TV. Chasis Nr.s are
P54A/J52A/PCL545R/SP43T6HF. My screen went black while I was watching TV but the sound was OK and I unplugged the Tv and a few hours later replugged, the picture came back for about 15 minutes but, went again. at the moment I have sound only. Replugging process did't work again.
I can't find the schematics :-(
Any solution and / or a scematic if you have would be great help
thanks in advance
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Posted on Jun 01, 2006
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
  • 1153 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
SHUT DOWN CAN BE INTERMITTENT OR AT POWER ON. CHECK FOR LEAKEY OR SHORTED Q570 PART # 260P560040 ON THE MAIN PCB.
Posted on Sep 19, 2007
SOURCE: Sony KF-50WE610
the color drive is going bad check with the sony service center it might be cover and repaired free.  my set went blue and the service tech is checking if it is covered.  good luck.
Posted on Oct 11, 2007
premtech
  • 934 Answers
SOURCE: Samsung Rear Projection screen went out.
MrPeab,
Where did you purchase the convergence amps previously? Your set takes two STK392-040 Sanyo amps and there is a high probability that that is the problem here again. The convergence amps for these units are really critical and chinese knock-offs are abundant. Is it possible that you didn't get Sanyo originals?
Another thought is what about the heat sink used when they were installed? Did you do the installation or have it done professionally?
Bill
I doubt seriously that unplugging the unit will have any affect.
Posted on Jan 30, 2008
TV MADE A LOUD "POP" NOSIE AND THEN SCREEN WENT
Hell k_sopata
If the display isn't working and according to the conditions you described yes it is the picture tube. You could contact Samsung and get a replacement for it.
Jan 10, 2011 | Samsung PCJ522R 52" Rear Projection...
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least.  Plug it back in and it should be ok.  It will re set itself.
Sep 30, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R Color adjustment!
i'd recommend you return it to your friend..sounds like quite an issue with the innards.
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
No green or blue color in pictures!
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Craig www.classtorations.com
White dots appearing on tv screen
Will need model number, but sounds like digi board problem
Mar 18, 2008 | Samsung PCL545R 54" Rear Projection...
SAMSUNG HDTV MODEL NO. PCL545R
Do you see any deteriation of picture quality before shut down ? This could be a number of diff problems. Need more info
Mar 16, 2008 | Samsung PCL545R 54" Rear Projection...
Black Lines when picture is bright
Are those lines all the way up/down your set? Or just in small zig-zags?
Dec 17, 2006 | Samsung PCL545R 54" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
