Csrcs.exe file messege I am receivng when I start or restart the system how can I solve this problem
  • 15 more comments
  • Anonymous Dec 11, 2008
    It isnt in there at all
  • thegr8tstewy Dec 15, 2008
    I'm also having that problem. I also can't find csrcs/csrcs.exe under the msconfig.
    Is there anything else we can do???
    Please help
    Thanks
  • Anonymous Jan 17, 2009
    windows cannot find 'csrcs.exe'. make sure you typed the name correctly and then try again. To search for a file click start button and then click search
  • Anonymous Jan 21, 2009
    my antivirus avg free.....
    it was deleted that file csrcs.exe wat  i have to do?
  • kirtivijayan Feb 03, 2009
    For Gods sake sb pls. help me, how to get rit of this csrcs.exe virus. It is eating my brain.
  • Anonymous Feb 22, 2009
    when my pc start it show windows can not find"csrcs.exe"file
  • vikram_R Feb 24, 2009
  • uday_steel Feb 24, 2009
    My operating system is xp and i have AVG TRIAL VERSION 8.0.eversince i downloaded this anti-virus i am facing the abovesaid problem-whenever i turn on my laptop i get the abovesaid message-please help me-uday
  • Anonymous Mar 06, 2009
    when i start up i get an error message saying csrcs.exe cannot be found
  • Anonymous Mar 17, 2009
    i cant find the CSRCS.exe on th system configuration utility -startup tab.,.
    Windows cannot find 'csrcs.exe'. Make sure you typed the name correctly, and then try again. To search for a file,rnclick the Start button, and then click Search.rnplease solve my problem
  • Anonymous Mar 30, 2009
    Windows cannot find 'csrcs.exe.'. Make sure you typed the name correctly, and then try again. To search for a file, click the Start, and then click Search.
  • Anonymous Mar 31, 2009
    i have the same problem. how can i solve it
  • darshmakot Apr 01, 2009
    I have the same problem,deleted file from registry and restarted the machine and cannot find the file in start up also.Any Guidelines....
  • Anonymous Apr 30, 2009
    when start up error message comes csrcs.exe missing
  • marcelogdiaz May 13, 2009
    Hi!!! I had the same problem and these tips seem to be the solution....so thanks!!!!!!!!!
  • Anonymous May 15, 2009
    "csrcs.exe file messege" problem, and notify you when a new solution is offered
What you do is START->Run. Then write "regedit". The registry editor will open. Press Ctrl+F (make sure you have "My Computer" highlited) and write "csrcs". The program will search for the entry and will find some entries: if you find a "csrcs" entry alone, delete it. If you find an entry "Explorer.exe csrcs.exe" modify it (right click->modify) and remove the "csrcs.exe" part.
Posted on May 09, 2009
Hi guys,
This is a easy one to fix. Click Start, then Run and type regedit.
Now press Ctrl and F to open the search box. Type in Csrcs.exe and click on OK.
Delete the file and search again. Now on the highlighted second finding, right click and choose modify.
Delete the CSRCS.EXE part after Explorer.exe. Do not delete the whole line, on CSRCS.EXE part.
And that's it, you're done.
Just restart.
Posted on Jan 14, 2010
    Novelist:
  • 183 Answers
Please Click on START Button
Click on RUN
Type MSCONFIG
Click OK
Go to startup Tab.
Look for CSRCS OR CSRCS.exe
Unchecked it
Click on Apply and OK
Restart the Computer.
If that still doesnot Resolve issue then Please let Me know.
Posted on Oct 22, 2008
I have a problem in my laptop is that when i started my pc it showned a massage csrcs.exe not file not found.
Posted on Feb 16, 2009
  • promhorl Jan 20, 2011
    your website is good,think you verry much this website show
    you about pcdownload see you again from
    www.pcdownload.asia
    www.penink.info
    www.phnomcambodia.com
    www.phnompenhpost.org
    www.picktorrent.info
When my pc start it show windows can not find"csrcs.exe"file
Posted on Feb 22, 2009
Csrcs only appears in the regedit
no csrcs.exe and explorer.exe
Posted on May 25, 2010
Kharkosdeh hadaghal ye bar khodet check mikardi
Bache Kooni in aslan tooyeh startup nist
Posted on Feb 06, 2009
  • kiavash599 Feb 06, 2009
    Kharkosdeh hadaghal yehbar khodet check mikardi.
    Bache Kooni in file aslan tooyeh startup nist.
    Kiram to dahanet
What if i deleted csrcs.exe including explorer.exe? how can i restore it? need help plz
Posted on Jan 29, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Hello friends!
reading the issues.. it makes me feel that your systems are possibly infected with some kind of a Trojan Variant. A combination of DOS and Windows Registry Knowledge to a fair amount helps a lot at times.
However, I think you guys must try what I've put down here.
I hope the below transcript should help you guys out for your problem; even as i have not faced this issue myself, I searched for a solution on the net for your problems and gathered this transcript for you. Hope this should help you guys...
Till then Happy Hunting!
From another PC download and install these two programs and copy the the installed folders to a USB Stick.
Restart the PC in Safe Mode and turn off System Restore, then run Sophos and then run Spybot.
Download Spybot - Search & Destroy 1.5.2 and install it. Update it. http://www.safer-networking.org/en/download/index.html
Download Sophos and the latest IDE Files. Install it and extract the IDE files to the C:\SAV32CLI folder.
http://www.sophos.com/support/knowledgebase/article/13251.html
Copy and paste the below two lines into Notepad and save the file to the USB Stick as sophos.bat, it will scan and remove. When the Scan has finished check the log file to see what it hasn't removed.
CD SAV32CLI
SAV32CLI -REMOVE -P=C:\REMOVLOG.TXT
The Sophos SAV32CLI folder can be safely deleted after it is copied to USB.
When you have finished running the above download and install Malwarebytes and update it. Reboot your PC in Safe Mode and run it.
http://download.bleepingcomputer.com/malwarebytes/mbam-setup.exe
Download RootkitRevealer v1.71 and run it
http://technet.microsoft.com/en-us/sysinternals/bb897445.aspx
Just to be on the safe side when you finish do an online scan with Bitdefender.
http://www.bitdefender.com/scan8/ie.html
Remember to turn on System Restore when you have finished cleaning.
Keep us informed as to your progress if you require further assistance.
Posted on Feb 18, 2009
CSRCS OR CSRCS.exe isnt in the tab at all
Posted on Dec 11, 2008
Windows cannot find 'csrcs.exe'. Make sure you typed the name correctly, and then try again. To search for a file. click the start button, and then click search.
What i Do.
by
rubesh
Posted on Mar 31, 2009
Hi, I am using HitechFone for P.C to Calling. now in our office server block this program. How can unblock this program?
Posted on Aug 11, 2010
With this help i found the csrcs and i deleted it. thank you.
Posted on May 15, 2009
Csrcs.exe removal
Steps to remove this virus:
1. Scan the system with a good and updated Anti Virus.
2. Open Task Manager, locate this exe (csrcs.exe or csrsc.exe but not csrss.exe), and kill the process.
3. Now type msconfig in the Run box, and then go to startup tab.
4. Locate this exe file, if any, and then remove it from there as well.
5. Now search the file in the C: drive.
6. Permanently delete the file (csrcs.exe or csrsc.exe only) from the computer.
7. Reboot the PC for changes to take place.
After doing the above steps, you need to clean the registry as well.
  1. Navigate toHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\
  2. On the right side, there is a key named "Shell", it may be having a value "explorer.exe csrcs.exe". Just modify it to delete the csrcs.exe from it (not explorer.exe). Restart the computer
Mar 20, 2011 | Microsoft Computers & Internet
Windows can not find csrcs.exe
Hi
Thank you for your query
You have a virus on your PC
Please carry out the following steps to remove it, please do not confuse csrcs for csrss which is a valid windows file
UPDATE
  1. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\
  2. On the right side, there is a key named “Shell”, it may be having a value “explorer.exe csrcs.exe”. Just modify it to delete the csrcs.exe from it (not explorer.exe). Restart the computer
Please finally re do a virus scan to ensure it has gone
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 16, 2010 | HP Computers & Internet
Troians Problem
Hi friend,,,,, First check CCleaner,software.
or go to run type regedit and find
HKEY_ LOCAL _ MACHINE\ Software\Microsoft\Windows NT\Current Version\Winlogon\
Here u will find a key with the name "shell" check whether the value of the key is something like " explorer.exe csrcs.exe " if u found 'csrcs.exe ' alone.delete it and restart thats all....a back up before doing this is good... thank u...please rate it
Nov 10, 2009 | Computers & Internet
When I scanned by System through Norten Antivirus........it diagnosed that csrcs.exe file/virus exists and must be cleaned/quarantined....so i quarantined it...when I started my system ..... after booting...
Its not a system file.
Try following
  • START-RUN,type there regedit(this will open system registry)
  • ctrl+F
  • Write csrcs(search now)
It'll show you some results, you'll find there "csrcs.exe",just delete it immediately.
If Its not over yet, again do the same search you may see "explorer.exe csrcs.exe" , left click then modify and remove the csrcs.exe part(leave the explorer.exe as it is)
Oct 04, 2009 | Dell Computers & Internet
I would like to know why I continually lose connection while playing YoVille game on Facebook? I'm usually in the middle of a game, and it says I need to refresh, which causes me to loose coins. I asked...
The free file information forum can help you find out if csrcs.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
csrcs.exe file information
The process belongs to the software CSRCS.EXE by unknown.
Description: File csrcs.exe is located in the folder C:WindowsSystem32.
Program has no file description. The program is not visible. The file is located in the Windows folder, but it is not a Windows core file. HKEY_CURRENT_USERSOFTWAREMicrosoftWindowsCurrentVersionRunOnce, HKEY_USERS.DEFAULTSoftwareMicrosoftWindowsCurrentVersionRunonce).
It is not a Windows system file. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to hide itself, monitor applications. Therefore the technical security rating is 100% dangerous.
Important: Some malware camouflage themselves as csrcs.exe, particularly if they are located in c:windows or c:windowssystem32 folder. Thus check the csrcs.exe process on your pc whether it is pest. We recommend Security Task Manager:
http://www.neuber.com/taskmanager/index.html?ref=file.net
for verifying your computer's security.
If this information is useful, please mark as helpful. Thanks
Oct 03, 2009 | Microsoft Windows XP Home Edition
Windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
Window cannot find file csrcs.exe
this is virus problem ur system is virus affected. please reinstall windows xp properly with all the drives formated and see that ur system is working properly.
Sep 05, 2009 | Compaq Computers & Internet
CSRCS.EXE
Click on RUN
Type MSCONFIG
Click OK
Go to startup Tab.
Unchecked it
If that still does not Resolve issue then Please let Me know.
Aug 28, 2009 | Computers & Internet
To get rid csrcs.exe. file
Find and Detect csrcs.exe on your PC. to find the file click search and put the file name and thn find its location from there and delete it. Remove, Uninstall and Get Rid of csrcs.exe
Jul 07, 2009 | Microsoft Windows XP Professional
Open Questions:
USA@#1-877-778-89-69@#Avira Customer Support Telephone Number? Call USA1-877-778-89-69 Avira tech support is offer the power of any time, anyplace with the assistance of Avira Antivirus support phone number . Any body will easy accessibility the Avira Antivirus Support Phone Number. Avira Antivirus Support number provides technical help and support services in respect to the software system .Our expert Solved all type of issues i.e Netwok conflicts,Firewall configuration and window issues etc. For more detail call:1-877-778-89-69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.
May 24, 2017 | Avira Computers & Internet
Computers & Internet Logo
23,791 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
