Question about Acer Aspire 5630 Notebook
No sound if audio is set to realtek digital output
When The same prob, but my one is Aspire 5720
  • 70 Answers
Have you tried updating the drivers?
Posted on Oct 22, 2008
Is it possible to get sound trough HDMI cable on an Acer Aspire L5100?
Sure, it may just not be enabled. On Windows PCs, you may have to go to the Control Panel and go to the SOUND tab. There you may find that you have to choose between the default analog sound out and the digital sound output thru the HDMI cable. If your system has an audio manager application (Realtek for example, uses one), you can select the digital output there as well. It may even be easier to do there.
Mar 04, 2015 | Acer Aspire L5100 (4496426) PC Desktop
Why does my Acer Aspire L5100 not have sound trough the HDMI cable?
It may have, but may not be enabled. On Windows PCs, you may have to go to the Control Panel and go to the SOUND tab. There you may find that you have to choose between the default analog sound out and the digital sound output thru the HDMI cable. If your system has an audio manager application (Realtek for example, uses one), you can select the digital output there as well. It may even be easier to do there.
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
I have an ACER Aspire 5720 notebook. The internal speakers stopped working once I put the 3.5mm headphone jack in. Now sound is only obtained when headphones are plugged in. Realtek High Definition...
hi
I don't think that you have to go for complete recovery.You can do it this way..
  • download the sound driver from the Acer's website and reinstall the driver after uninstalling the previous version.
  • restart the system and you will everything back in shape.
thankyou
Jul 16, 2009 | Acer Aspire 5720-6661 Notebook PC
No sound coming from the realtek digital output
u can check sound stall or not two way as 1/ right mouse click-clik hardwere click device manager then look sound option ,if sound is not stal u con see there yello sign in speaker. if not stall sound keeping ur bord cd ,u can stall sound. 2/ go run type control and click sound and audio option then look on audio device property . if setting is incorrect correct it ----- thanks
Jun 14, 2009 | Acer Aspire 4520-5582 Notebook
Realtek digital output no sound
hi..if you have a mother board installer try update the driver sound but 1st remove the old driver from your PC/unit..good luck..good day...^_^
Jun 10, 2009 | Acer Aspire 4520-5582 Notebook
No sound devices on laptop
This is most likely a simple driver glitch. You can fix it by uninstalling the audio drivers from the device manager, then reboot. The machine will find the sound card and reinstall the drivers automatically. This should fix it, if not let me know.
Aug 28, 2008 | Acer Aspire 4520-5582 Notebook
THe realtek Digital Output will only output sound if you have an optical cable attached. this allows you to connect your laptop a audio receiver via an optical cable. this is why you get no sound when it is set to digital output.
Apr 19, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5720-4126 Line In Audio
try going to your control panel, volume controls then goto Audio Properties and see what your defaul devices are.
change them all to ur hd audio.
hope this helps.
Mar 31, 2008 | Computers & Internet
Acer Aspire 5630 Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
