Usb device not recognized
Hi my usb device is not recognized, i just used it but when i use it again,, it was not recognized,..
i tried different computers but the result is still the same,..
need help!please!
  • 4 Answers
Hi i had a similar problem but mine was with a new HDD but you could try it and see if it helps at all:
Try looking for the drive in the "Disk Management".
Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
mine needed to be initialized (by right clicking on it) and then i formated it
Good Luck!
Posted on Oct 26, 2008
How do I get my USB in my vehicle working again?
You might want to try connecting a USB memory stick / thumbdrive formatted differently than is current. Some choices are FAT16, FAT32, NTFS, exFAT and others still. Your computer may recognize several of these - but car manufacturers usually aren't quite as up to date as computer / software companies.
If you're using an unsupported format on a thumbdrive - it may not recognize it. If you're using the USB for a different device (tablet, cellphone, charger, etc.) check to see if the connected device reports power present - if not - no amount of trying with various formats will get it to work. You'll need to address the lack of power at the USB first. Check your owner manual for the location of the fuse(s) that provide power to the USB ports.
Dec 03, 2014 | Office Equipment & Supplies
Hi my wireless has just gone it is not recognized in the device manager and a USB Device not Recognized pop up is showing up. i restart it a couple of times and once it did showed up but after i did it...
Try unplugging the wireless adapter and plugging into a different usb connection. Windows will install it and then check if it works. You can also try uninstalling the adapter from the device manager and search the manufacturers support website for the driver download page. You should be able to find the wireless adapter driver here, download and follow installation instructions to install a new one.
Mar 28, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
COMPUTER NOT RECOGNIZING MY USB
please try another usb device on your computer and check if it will be recognized.
If it does not recognize it try using a different port. If you have a USB keyboard and mouse try to swap it and check if that will work.
You can also try that USB device onto another computer and check if it will work.
This way you will know if its device or the port that is faulty.
Hope this helps!
Jun 20, 2011 | Computers & Internet
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
My battery wont recharge when i plug it into the computer
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
NOTE: If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below: Check for available space on the player using Windows Media Player or My Computer . Restart the computer. Check the connection status again and try to sync the player. Check that the USB cable is firmly connected to both the computer and the player. Check the connection status again and try to sync the player. If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable. Check the connection status again and try to sync the player. If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer. After the computer restarts, connect only the Walkman portable player and test the connection again. If the player is still not recognized by the computer, try a different USB port. Check the connection status again and try to sync the player. Under the Common settings menu of the player, format the player using the built-in Format utility. Check the connection status again and try to sync the player. Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system. If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later. If you did not have the latest service pack, test the connection status again after it has been installed. If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Sep 22, 2009 | Sony Walkman Video NWZA818 MP3 Player
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
Sep 16, 2009 | Canon VIXIA HV30 DV Camcorder
EasyShare DX6440 "USB Device not recognized"
What operating system are you using?
If you have xp or vista, you can uninstall the software and transfer the pictures since these operating system has built in drivers.
Jun 23, 2009 | Kodak EasyShare DX6440 Digital Camera
Canon MP240
Have a look at this link
http://windowsfixup.com/2009/03/usb-device-not-recognized-fixes/
"Delete the INFCACHE" has worked for me in the past.
Also I found that I was using a non USB 2.0 cable which caused the "unrecognized USB" problem. Once I used a proper USB 2.0 cable it was fine.
Hope that helps.
May 11, 2009 | Office Equipment & Supplies
Mio p550 USB devise not recognized.
Try a other usb cable had same problem new cable fixed it of other device
Nov 09, 2007 | Mitac Mio P550 GPS Receiver
Computers & Internet Logo
529 people viewed this question
David Payne
David Payne
