Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
Kenmore upright freezer
When I plug in freezer it trips the GFI.. the GFI is good,,,,
unit is 8 years old
  • skippybuzz Oct 22, 2008
    does this mean the compressor should be replaced?? or maybe a new freezers""" can the compressor be unlocked??
    Genius:
  • 1,122 Answers
Sounds like you have compressor lockup-mike
Posted on Oct 22, 2008
  • MIKE major Oct 22, 2008
    if you have a meter you can do a amp check on the compressor,you can look on the comp. and you will see your lra reading(locked rotor amps reading)your comp. should pull no more then 2-5 amps ,over that tells you your comp. is about to fail,if you don't have a meter, you can go to your local appliance part store and ask them for a 3in1 starter for your freezer,it is easy to put on the directions are on it,let me now how you do-mike
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer stopped working
A no power to the compressor is a good sign as far as being repairable is concerned. Locate the temperature control. Unplug the freezer and jumper the two main wires that connect to the control. Plug it in and if the unit runs replace the thermostat.
Jul 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Power Outage?
johnny try to connect the fridge using a stabliser to the wall plug and make the control to the min coll and check if it is ok then the problem is of the connecting load to the wall plug
Jul 03, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
172 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
