My printer shows error 6000 on the lcd screen. How do I fix it? at the moment I cannot use my pinter scanner fax.
  • 3,940 Answers
If this is a Canon printer, then this indicates a paper jam. Ensure the paper path is clear and no debris is present and that no sheets of paper have gotten in a bind in the printer. If the paper path is clear, you'll need to contact canon for service/repair of the printer.
Posted on Oct 22, 2008
Why is my hp Laserjet pro 400 mfp 475dw not showing on the LCD as well as scanner calibration
I have had to replace the lcd screen on several of these. Does the unit go thorugh the powerup noises such as fuser rotation and scanner hunting for home? If not, might be the power supply.
Aug 19, 2014 | HP LaserJet Pro 400 color MFP M475dw -...
54.2 printer error
59.4 - Fuser motor error: Verify that the fuser is seated completely. If the error persists, contact Hewlett-Packard for technical support to troubleshoot the problem.
Hope this will help you.
Please rate me if its helpful to you.
Sep 19, 2012 | HP Color LaserJet 2840 All-in-One...
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Paper jam on kodak pinter but no paper is in pinter and keeps saying paper jam
make sure to fan all sheets several times before loading, both from the 8.5" side, and also the 11" side. fixed my problem. hope it will fix yours
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mfc 440cn touble msg: unable to init af on the screen,
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with thearrow down (round) key. You'll find an entry listed as purge count.If number is over 6000, enter 2 7 8 3.
This will reset thepurge count value. Then the printer will restart, hopefully withoutthe annoying cannot clean message.
Oct 21, 2009 | Office Equipment & Supplies
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scanner bar seems jammed, printer shows busy, all docs cancelled
Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error code 6000 is showing on the lcd screen how fix problem?
what model printer? 6000 codes are usually related to the fuser section.
May 06, 2008 | Office Equipment & Supplies
Scanner error message hp laserjet 3030
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
