Well may kodak v603 was dropped and the screen broke but everything else is fine so i am wondering if this can be fixed and cheaply. i live in sydney so anyone know any cheap places to get it fixEd?
LCD replacement is compulsary, for that i suggest only kodak shop, because LCD costs same anywhere in the world, onle service charge differs and that is i think not so much.
so go to kodak only..
Check the camera for a "DISP" button, (short for display) if there isn't one, or there is and you pressed it, will it take pictures? if yes, then the LCD screen ribbon has probably been disconnected.
Have you contacted Kodak for warranty coverage? If the LCD is broke due to a camera malfunction and not user error, they will fix it for free. If it's due to being dropped or "user error" they will charge you to fix it. And if you opt to not have it fixed and just sent back to you, it'll cost $35.
Seems the lens mechanism is stuck and would need to be taken apart, its best to send the camera in for repair. http://www.advancecamera.com/repair <- Get a free estimate from there.
Hmm.. I'd say consider selling the camera on E-bay. Be honest about the camera's condition. If the LCD isn't broken, there are many people who would like to buy your camera and use it repair their own. I'd expect to make anywhere from $20 to $40 dollars if the screen isn't broken. The screen on the Kodak 603V breaks pretty easy. I just bought a broken camera to fix my camera with... Sorry I don't have better advice. I would not call Kodak. I did and they wanted about $100 to fix my camera.
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
