HP3210 will not print in black
I am having trouble with printing in black.I have tried vrious suggested solutions e.g. re setting,reinstalling the software/cleaning printhead/pressing down OK/cancel/black/colour buttons and removing the power chord.It prints ok with all other colours when they are selected but not with black.
HP of America have tried to be helpful but say that it is a hardware fault I and I need to send it to HP UK for repair. They are useless - I can't even get hold of them and when I did they suggested buying a new printer as this one was out of warranty.It is 1.5 years old.
Any suggestions,
  • 88 Answers
SOURCE: i860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Posted on Apr 09, 2008
  • 300 Answers
SOURCE: Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Posted on Jun 03, 2008
  • 3614 Answers
SOURCE: Canon iP4500 colour management
go to control panel>> select prinnter and faxes>> there right click the icon of your printer and click properties...
Posted on Aug 08, 2008
  • 138 Answers
SOURCE: I have a 13 month old HP Photosmart C5180 which is
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Posted on Sep 28, 2009
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
Hp printer error massage no black ink supply NEW CARTIDGE IN have tried reinstalling several time
Hi Jack,
What I understand from your message is that, when you try to print from the computer, you are receiving a message "No black ink supply"...
Solution: If you have installed the full featured AIO software on your computer, then open the HP solution Center on your computer, then click on the settings>> print settings>> Printer toolbox.
Then click on the Configuration Tab and uncheck the option "Display the ink level message". Then click on the Device tab and try to print a Diagnostic page and then click Ok to close the solution center. Then resart the computer and try printing..
I am pretty sure this will resolve the issue..
With Regards
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP3210 -is not printing the full document only the heading
Go into "Printers and faxes" under "Control Panel"
Right Click on the Printer and select "Properties"
Look for a "maintenance" or "Tools" option then Try
"Cleaning" or "Deep Cleaning"
Jan 12, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP 3210 Multi-page print problem
Dear Martin Luke,
Take a look at the posts on "black ink problem" on this site. There are 9 offers of solution.
Many of us with this defectively-designed model have the same problem. Some say the answer is to do with button pressing, but action may need to be more radical and messy, and involves forcing the blockage out of the ink feeder tube etc.
Dec 30, 2008 | HP Photosmart 3210 Printer
Black ink not printing
1. turn off the printer and open the front panel of printer
2. clean right side box wr all cartridge are stop
3. then change black cartridge
Mar 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Its not printing in black
you need to replace your new cartrige. Im sure it has warranty
Feb 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Printer will not print black ink
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Jun 25, 2007 | Canon i850 InkJet Photo Printer
41 people viewed this question
