Question about RCA 27F530T 27" TV
No picture or sound.
I have good power supp.,good fuses, and no bad solder in board,no apparent heat or smell. I have power @ switch,at least the light is ill. as soon as you plug the unit in, and you can hear a faint clicking sound for a sec. as if a cap is storing power. But no pic. or aud. Why is power indicator on before I push power button? No change after pushing power button.
  • 1 more comment
  • David Hardy Jul 31, 2006
    To Ted Marx38; Again, as I said "no disrespect intended," I was just eager for an idea.--DrDave
    To Techman; Thanks for the specs. And for the thought, but yes, I am qualified.:) Have a great day!!--DrDave
  • David Hardy Aug 05, 2006
    Well I don't know if this is the right way to go about this, but I am new to this site, so here goes; I solved my problem after satisfying my flow chart and finding nothing. So I decided to try an aftermarket remote. But, since I lost my code list, I had to try and retrieve the code via auto search. I entered the correct code and Viola, on comes A & V! I went into the menu and reset the parental lock to "off", and the front panel became operational!--SWEET:) The code for this GE remote was 100
    I have control over all func. except switch to video in..which does suck, but after i locate a factory remote, that issue will be cured. Simple fix, Free TV!!!:)
    Thanks again, I will be back--DrDave
  • 60wayne Nov 16, 2007
    Have power, clicks but not video and no sound. Problem was parental control on (dont know why) so I followed procedure to reset by holding both volumn down (on TV) and clear (on remote) for 5 seconds. It worked. Have a working TV again. Thanks DRDave for the solution and without any cost!
    President:
  • 3,130 Answers
How do you know the power supplys good? Its probably whats always bad on these sets. If the horizontal output is shorted, the flyback is also bad. The the HOT is not shorted, take a scope and on plugging in the set make sure you have a drive waveform, at least 3 to 6 Volts PIV. If you have all the proper tools and equipment, this is an easy set to troubleshoot. If you dont and trying to fix it with a multi-meter alone, Sorry is'ent going to happen. A TV set is not a place to go into and experiment with. Its a solid state set so there are no user serviceable parts inside. Please! Take this set into a pro to be diagnoised and serviced before you end up hurting yourself and or causeing much more damage to the set then there already is.. Good Luck
Posted on Jul 30, 2006
Dave, see the solution I posted on the other thread, the one where you made the comment. This link should work. http://www.fixya.com/support/t114288-rca_buttons_remote_work
Posted on Jul 31, 2006
Furnace wont heat or go to cooling....fuse is fine
With volt-ohm meter (vom) check for 24v input power. Most output voltage will be 5v DC, check for that. If the relays are soldered on to the board, your only solution is to replace the board. A "ticking" sound may be a bad relay. One check you can make is to disconnect any incoming power to the unit and remove the board. Inspect the soldered side of the board, if you see any black or brown spots, most likely the board is bad and will need to be replaced.
Nov 06, 2013 | Heating & Cooling
Burnt smell blush picture
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Dec 22, 2007 | Samsung PCN5425R 54" Rear Projection...
The color stay dark on the screen
I am assuming audio is fine, no picture.
Either the power supply has some bad capacitors in the 24 volt section that supplies the inverter board, or the inverter board has some bad capacitors.
You can confirm this with a flashlight held at an angle to the screen up close, you will see the screen image darkly.
It is also possible both boards suffer from cold solder joints- which just need to be reflowed with a small amount of fresh solder to get it the old solder to flow again.
If no picture and no sound, power supply board is likely the culprit with bad capacitors, a blown fuse, or bad solder joints.
Dec 31, 2011 | Samsung 225BW Monitor
N3250W: Sound w/ no picture.
you may have a bad inverter board. check for 24volts to the board.
Dec 30, 2009 | ViewSonic N3250W Television
JBL Powerbass PB12 When left on, will make very loud sound
Before you spend a lot of money, try checking for these:
- poorly soldered or partially desoldered wires, connectors (power, signal input) or ANY other components (especially the ones that tend to heat up, like power transistors or voltage regulators - a component which has been heating up will cause the curcuit board around it to become somewhat darker)
- dirty or oxydized contacts on ANY of the connectors or switches
- partially or fully blown electrolytic capacitors (see if any are damaged, bulged or blown at the top, these surely need to be replaced)
- internally damaged tantalum electrolytic capacitors (probably there will be no apparent damage to these, but they may cause intermittent disturbances if they are bad).
It may as well be something else, but if your equipment was being used extensively during these 6-8 years, it is likely that some capacitors may have dried up or otherwise failed.
It is also likely that the sound vibrations caused loose connections or bad solder contacts on the circuit board since it is a powered sub with an integrated amp (many audio devices get to suffer from bad solder contacts just by heating up with years of use and even without being exposed to powerful sound vibrations).
I hope you can get it to work well again.
regards
3rq8 (Triarcuate)
Sep 07, 2009 | Audio Players & Recorders
Will not heat!
Hi!
In most of the cases, this is usually due to a bad magnetron, the other time is sometimes a bad high voltage diode which you have already replaced.
Most of the common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay or a bad door switch. Other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Please check all these to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 21, 2009 | Microwave Ovens
Audiosonic KMCTH68 Keeps turning itself off after 2 mins
CHEAP TV VIDEO REPAIRS
Can't be 100% sure but the most likely cause of the problem is bad solder connections in the switch mode power supply or on the vertical output IC, or anywhere on the main or picture tube circuit boards, due to age and switching on and off TV's develop bad solder connections when cold the connection is made and when it warms up due to heat expansion the connection breaks, you will need to be handy with a soldering iron, and discharge all power supplies with something like a 100 Watt globe before soldering or you may blow things up and do really serious damage, and be warned TV 's have very high voltages 360 volts DC in the SMPS primary and over 20,000 volts to the picture tube, so be careful.
Feb 03, 2009 | Panasonic PT-40LC12 40" Rear Projection...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Toshiba CF30E50 TV shuts off
Best first step is: Good visual inspection = look for hot spots
on PCB, check caps in those areas + solder any/all bad connections,esp. low voltage regulator pins.Look the whole
board over with magnifier = solder,solder,solder...T.
Oct 25, 2007 | Televison & Video
Have sound and no picture
HI I HAVE THE SOUND BUT NO PICTURE BAT WHEN I BEND THE POWER BOARD OR PLAY WITH IT LEFT OR RIGHT THSN I GET THE PICTURE
Oct 02, 2006 | Toshiba 50HX70 50" Rear Projection...
RCA 27F530T 27" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
