Question about HP PSC 2510 All-In-One InkJet Printer
Unit wont start up after power failure
Having same problem as Nonickname's psc 2410: That is, after power failure w/ psc 2510 running XP sp2, unit wont start up. Unit powers up then the hourglass on the lcd screen continuosly loops. Tried uninstall an reinstall of driver. did not work. tried to install on another computer via usb...also failed. Powers up, hourglass infinite loops, unless press power up button. Then device "recognizes" (but it really doesnt). Radio blue light will not come on. Tried USB connect, CAT 5 connect..nothing works. Is the unit fried?
  • Anonymous Mar 27, 2014
    the power button lights up,but the lcd fails to light up.removed the leads,also restarted the pc.made sure the leads are connected correctly,stil the same problem.
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Posted on Apr 30, 2007
In windows xp sp2 my os did not recocnize my mouse. Previously it was working fine. But from 19/5/2010 it not recognize and when windows start it stuck in the middle of the screen. i tried with three...
Bro it is a normal problem of some hardware component units, depend on its hardware manufacturer. because some of the system units need to plug first all the peripherals before you start-up using the computer unit so that it will analyse and familiarize all the peripherals attach on it during reboot mode.Bro follow this steps. 1.plug your PS/2 or USB mouse connector to its port at the back of your system unit.
2. turn off or restart your system unit. 3. or turn on the system unit if you're using turn off mode. 4. wait while the hardware is on reboot mode till windows logo appears.
May 20, 2010 | Computers & Internet
Scanner failure on HP psc 750
* Does the unit scan properly from front panel button?
* Does the unit scan properly from HP Director software?
* Does the unit make stand alone copy properly? (please make a copy from the unit with out connecting to the computer)
Please get back to me with the above information
:) Dr Tony
Apr 15, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP 1610 "scanner Failure" message
It MIGHT be that the unit is no good. The downside of ALL IN ONE products. BUT, unplug the power cord from the back of the all in one, then unplug the USB cable, then unplug power cord from wall. Wait 10 minutes and plug everything back in in reverse order and see if it works. If not it is bad.
Jan 18, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 750 scanner failure message
Remove power and leave out for 30 seconds. Hold cancel and left arrow and reinsert the power. Attempt to copy, if it still does not work you may need to have the unit serviced. Technical support can set-up an exchange if in/out of warranty, if out... it will be more that $100 for another unit. You can try to call some local providers for a quote on prices as they vary from ASP.
Cheers!
Oct 26, 2008 | HP PSC 950 All-In-One InkJet Printer
CAN I RUN MSWINDOWS XP SP2 ON THIS MS7308E BOARD
not much choice here. seems like the Windows Xp operating system having probelm itself.
re-install Windows Xp. then you can go on the internet and download the driver file you need.
first thing first.
Oct 14, 2008 | Matsonic MS7308E (MBMS7308E) Motherboard
HP PSC 1610xi Will not scan have installed software manytimes to no avail. the unit will start to scan and then locks up. have to unplug power to unit toget unit up again and then indicates unit is...
If you are having problem whit your scanner/printer, do the following:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation.
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
This will fix your problem.
Oct 08, 2008 | HP Office Equipment & Supplies
Need User Guide
Um; just a thought but if it's software is Win98 and if your system is running XP SP2 or Vista I'd say you really do need a Guru. A simple answer like running in 98 mode under XP/Vista may not work.
As far as the manual goes, "Google" will generally get you what you want. I did and got www.labx.com as a starting point for your manual. many other lisings for it..
Aug 29, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Scanner does not work at all - no power now to the device
u could try new adpter how much are they online compare dto new lexmark flat bed scaner
Jan 21, 2008 | Visioneer 9020 Flatbed Scanner
HP PSC 2510 All-In-One InkJet Printer Logo
426 people viewed this question
Clive
Clive
