Question about Hotpoint Aquarius WF000 Front Load Washer
SMELLY WASHING MACHINE
My Hotpoint Aquarius wf540 is almost 3 years old. Inside the drum the machine smells damp, mouldy. The washing smells quite sweet when taken out after a wash and also after drying but an unpleasant smell develops after storing like damp dogs!
Does anyone have a solution/suggestion?
PS my machine is also very noisy on spin, it also moves across the floor so my husband has had to fasten it back to the wall with a chain, various Hotpoint engineers have been out to look at it with no solution.
Alison
  • jasa14 Oct 22, 2008
    try running the washing machine with a dishwashing tablet in it on normal wash.
  • mcleary7 Mar 01, 2009
    Ref-Hotpoint wf540. Same smelly fault after wash,its as if the clothes are not getting rinsed enough. Tried Hotpoints limescale/detergent remover but problem remains. Is there a filter on the machine that can be cleaned. I can't find any.
I have a hotpoint wf540 washing machine. when set to a cycle it will not continur through cycle. have to turn dial to empty drum then turn to rinse and spin etc. is the pcb at fAULT
Posted on Jun 07, 2011
  • 566 Answers
Hi the previous replys to your problem i hope solve the smell however if not? may i ask does your water waste pipe from the machine drain via a seperate waste pipe that goes thro the wall and direct to drain? as some do ? or connect to the adaptor connection on the sink U bend? if it is 1st type of drain it may be that the actual smell is coming from the drain or a nearby sewer that may be blocked ? and fumes take a short time to perculate up your machines waste pipe ? i have come across this prob in past and raised manhole nearby to find scourse of smell was sewer blockage drain rodded and sanizal fluid cleared it up hope this helps? if other solutions fail?
Posted on Oct 22, 2008
  • 417 Answers
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
WF250 washing machine. Drum smells and clothes smell a bit too. have tried boil wash but no improvement. Washing machine is 6 years old and has no other faults. Can you help?
Due to mainly running low temp washes and bacteria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe) many machines will begin to smell, generally the smell is described as a damp flannel!. This can be transferred to the wash load if like myself you tend to put a load on before going to work and then removing when you get home. (The washing is clean but smells disgusting!!!)
Run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) If you buy stores own as it is cheaper than miltons. The first time you need to do this, run the cycle twice to be sure it was cleared out.
My machine is six years old and the first smelly signs were when it was about a year old, I do mainly 30 and 40 degree washes with and occasional 60.
I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months.
Hope this helps. Roni.
(ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Sep 11, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I WANT TO CLEAN OUT THE FILTERS BUT CAN'T FIND THEM. tHE WASHING MACHINE IS 3 YEARS OLD AND IS WORKING BUT IS A BIT SMELLY AND CLOTHES ARE NOT AS CLEAN. I USE REAL NAPPIES AND USE THE MACHINE DAILY SO IT'S...
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf440 : my washing 'smells' after a wash so think filter needs changed/cleaned; where is it located, have lost my manual?
if i were you i would buy some detergent that cleans washers in the normal wash cycle without no clothes in it then you will find that the smell as gone,do this regular once a month to keep all the pipes fresh.rgrds,paul
Jul 07, 2009 | Hotpoint Aquarius WD63 Front Load...
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
747 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
