Panel Lock on Toshiba LCD 27/30WL46 Sereies -- how to Unlock?
I have inadvertantly put the Panel Lock function on while making some changes to the TV set-up. This was done through the buttons on the TV itself since the remote no longer works. Problem is that I can't now "Unlock" the panel because it appears this can only be done through the remote. Are there any button combinations on the TV that will unlock it for me?!
  • Anonymous Dec 20, 2008
    the tv panel is locked and i cant not unlock it my good man
  • Anonymous Jan 06, 2009
    La télécommande ne répond plus et lorsqu'on touche le clavier de la télévision celle-ci indique: bloquage clavier.comment faire pour dévérouiller la télécommande de la télé et le clavier.
    Merci d'avance.
I WOULD LIKE TO KNOW HOW COME EVERY TIME THAT I EXTINGUISH THE TV á. THE ACCENE THE MEMORY HIM AZZERA,SE POSSIBILE TO KNOW ITS MOTIVE
Posted on Jul 10, 2009
How can i unlock the panel lock
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given
Mar 08, 2015 | Toshiba 24PB1 24 inch Multi System LCD TV
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Lock panel tv unlock
when you're on the "enter pin code" screen press "recall" 4 times within 5 seconds. this should reset the pin code and allow you to enter a new one.
Toshiba 37HL67 Manual Info on page 47
Nov 03, 2013 | Toshiba 37HL67 37 in. LCD HDTV
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Nov 04, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
How do I unlock the 'panel lock' of my Toshiba Regza without remote control?
Hello
To unlock the panel lock of Toshiba TV, follow this.
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Mar 24, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Remote control brocken and dont know how to turn on tv without it
hi,
just press the power button or channel up button or down button on the pannel of your tv.
ok
Mar 07, 2011 | Toshiba 37C3030D 37 in. LCD Television
A lock turns up in the middle of the screen
You have inadvertently locked the On Screen Display (OSD).
To unlock do the following:
Press the menu button, which will take you directly to the OSD settings menu, and you will see 'OSD Lock' is selected. Change the seeting to No(-) to unlock and allow user access to all applicable settings.
Mar 07, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Tv wont turn on. toshiba 37c3030d
The internal power supply has died. take it to a repair facility.
Aug 13, 2009 | Toshiba 37C3030D 37 in. LCD Television
Televison & Video Logo
1,326 people viewed this question
Top Televison & Video Experts
