Question about Dell 922 All-In-One InkJet Printer
Printer faulty printer will not turn on
  • 1,269 Answers
Try to plug it to a different power outlet first. If it still doesn't turn on, you can try replacing the power cable of the printer. It could just be a defective power cable. If that didn't help, your printer is really faulty hence, you need to buy a new one or claim your warranty.
Posted on Oct 22, 2008
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
Feb 21, 2015 | Zebra Z4Mplus Label Printer
When i turn on my printer hp35550 after initialize it stop and error 59.99
It appears this error can be caused by several things.
I found this on HP's website:
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Also, I found a few people simply replaced the power supply and it fixed the problem.
I wish I had better more concise solution.
I wish you the best of luck
Mar 02, 2011 | HP Color LaserJet 3500 Printer
My Canon PIX MA Mp160 wont scan i got this error it says error in scanner turn of scanner and error code is 61,34,0
Normally MP160 cannot scan is either USB cable faulty, LOGIC BOARD ASSY faulty, software corrupted or SCANNER UNIT faulty.
May 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
When I turn on my Samsung CLP-600N laser printer, I just get a clicking noise. When I turn it off, it continues to click for a minute or two and then stops. The lights do not go on.
it sounds like a faulty power supply, when you apply power it charges the capacitors in the psu but as it is faulty is unstable hence the clicking, it continues as the capacitor discharge until all power drains
Apr 20, 2010 | Samsung CLP-600N Laser Printer
check out the power supply board is it getting 240 volt at its power ic or not.
if its not getting then the board is faulty.if getting more then 240 then any of the component on the board is faulty so it can be repaired.but if less then 240 volt then whole board is faulty and needs replacement.
thank tyou for using fixya.
Apr 03, 2009 | Xerox 8830 Copier
My Hp Deskjet D4160 printer wont turn on
the power cord wire is faulty or the main board in the printer is faulty.
if wire is faulty get it replaced its very negligible.if board is the problem.replace the printer.
its very costly to get board replaced.
Apr 01, 2009 | HP Deskjet D4160 InkJet Photo Printer
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Hp 2355 all in one printer
Can you turn on the printer normally? If you can't then you have a faulty power adaptor. If you can then it sounds like the connection between the computer and printer has been lost. Disconnect the printer and reconnect to another USB port. If this works then fine, if not then try another device in the same usb port to check wither the usb port is functioning. If it does, you have a faulty printer. You might be able to clear any probelms in the printer by performing a full reset.
Ppower up the printer and discconect the power supply while the printer is running. Hold the OK and Cancel buttons while reconnecting the power supply. When the printer switches off after 10-20 seconds, release the buttons, unplug the power and reinsert it. Turn on the printer and reun through the processes before plugging inth e USB. If it is still faulty, throw it away!!
Let me know what happens
Jun 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Printer light go off.
this problem could be caused by settings on printer driver setup or a faulty USB cable. but it also can be a faulty logic board in the printer as well.
Nov 27, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Dell 922 All-In-One InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
